Drives: 2015 FRS
Parking lights not working, fuse is fine
I noticed one of my license plate lights were blinking earlier tonight, I decided to pop the trunk and make sure the connection was fine and that the bulb didnt need to be pressed in. After pushing the bulb in a little further (with the car on, not sure if that could've been the cause), the front running lights, rear running lights, and both license plate lights stopped working. I have had the running light fuse blow before, so I went to go check and just decided to replace it even though it wasnt blown, they still arent working. Any recommendations? Don't want to get a ticket
Rust bucket enthusiast
It could have blown other fuses. Do your brake lights still work?
Drives: 2015 FRS
Yes, its the exact lights that went out when my parking light fuse did blow. I checked all fuses and they are fine. Im wondering if somehow a short in the license plate lights could be causing the whole system to not work but somehow not blowing the fuse? idk. I just ordered new lights to fix the flickering one so I will see if that works later this week.
#4 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (04-30-2019) |
Drives: RAVEN FRS
check the wires between the trunk and body through the grommet. Potentially a wire could be broken
| The Following User Says Thank You to darko For This Useful Post: | Tcoat (04-30-2019) |
| Parking Lights Fuse Location | NAEightySix | Electronics | Audio | NAV | Infotainment | 5 | 08-27-2017 10:46 PM |
| Power Outlet in Center Console not Working (Not a Blown Fuse) | DemonRawr | Issues | Warranty | Recalls / TSB | 3 | 06-06-2016 04:14 PM |
| Led strip on parking light T10 bulb? Amperage fuse | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 03-17-2014 02:34 AM |
| Fuse for parking/fog lights | Bg8780 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-27-2013 08:17 PM |
| Parking/fog lights not working | THEWAKLER | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-09-2013 08:26 PM |
