Old 04-29-2019, 10:03 PM   #1
LukeFRS
Drives: 2015 FRS
Parking lights not working, fuse is fine
I noticed one of my license plate lights were blinking earlier tonight, I decided to pop the trunk and make sure the connection was fine and that the bulb didnt need to be pressed in. After pushing the bulb in a little further (with the car on, not sure if that could've been the cause), the front running lights, rear running lights, and both license plate lights stopped working. I have had the running light fuse blow before, so I went to go check and just decided to replace it even though it wasnt blown, they still arent working. Any recommendations? Don't want to get a ticket
LukeFRS is offline   Reply With Quote
Old 04-29-2019, 10:07 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It could have blown other fuses. Do your brake lights still work?
Old 04-29-2019, 10:09 PM   #3
LukeFRS
Drives: 2015 FRS
Yes, its the exact lights that went out when my parking light fuse did blow. I checked all fuses and they are fine. Im wondering if somehow a short in the license plate lights could be causing the whole system to not work but somehow not blowing the fuse? idk. I just ordered new lights to fix the flickering one so I will see if that works later this week.
Old 04-30-2019, 10:11 AM   #4
Are all your lights stock? You need to find the root cause not just keep swapping fuses. There could be a break in the wire that doesn't create a short to blow the fuse.
soundman98 (04-30-2019)
Old 04-30-2019, 01:07 PM   #5
darko
Drives: RAVEN FRS
check the wires between the trunk and body through the grommet. Potentially a wire could be broken
darko is offline   Reply With Quote
The Following User Says Thank You to darko For This Useful Post:
Tcoat (04-30-2019)
Parking Lights Fuse Location NAEightySix Electronics | Audio | NAV | Infotainment 5 08-27-2017 10:46 PM
Power Outlet in Center Console not Working (Not a Blown Fuse) DemonRawr Issues | Warranty | Recalls / TSB 3 06-06-2016 04:14 PM
Led strip on parking light T10 bulb? Amperage fuse dssence Cosmetic Modification (Interior/Exterior/Lighting) 32 03-17-2014 02:34 AM
Fuse for parking/fog lights Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-27-2013 08:17 PM
Parking/fog lights not working THEWAKLER Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2013 08:26 PM
