| Engine Swaps Discussion of engine swaps. |
Drives: Scion frs
Engine not starting after swap
I swapped my fa20 for another low mileage one and now this b isnt starting
I love peanut butter
Drives: 2013 SWP BRZ Limited
This b is wylin'
Drives: Scion frs
guys i figured it out, its my crankshaft position sensor
![]() ![]() Sent from my iPhone using Tapatalk |
Drives: Scion frs
#6 | |
Actually this plate goes between the crank pulley and flywheel so it wouldn’t come off on a clutch job anyways. I was just throwing it out as an possibly incase you got an engine without this plate and transferred it over from your original engine. I’ve read about people installing it where the tabs are pointed out rather than in. |
Drives: 14 BSP Edelbrock BRZ
The plate 'lock in' is accomplished with a pin on the crank and a hole in the trigger plate. If the pin isn't in that hole your flywheel won't bolt on flat against the crank. You would know that in a hurry.
#8 | |
Drives: Scion frs
![]() that plate becomes loose once the flywheel is removed, im positive it wasn’t aligned right since i was rushing to get the engine moved out of the way (Garage space is limited) |
I've done two flywheels in the last month. I know what piece you are talking about. That plate has a hole in it that fits onto a locating pin on the crankshaft itself. If the flywheel was bolted on and the plate was not fit correctly on the locating pin the plate would not lay flat against the crankshaft and in turn the flywheel would not lay flat when bolted on.
#10 | |
I Love custom Turbo kits
Drives: Limited BRZ
I know of a shop installing the plate out of pin position and still bolting the flywheel up and the car throwing random timing codes. A few grand later the problem was discovered by a different shop..... Sad reacts only.
#11 | |
Drives: Scion frs
sadly my car is at a shop rn, labor costs would be higher than i expected Sent from my iPhone using Tapatalk |
#12 |
Did they shear the pin off? That pin sticks out about an eighth of an inch - the flywheel/cltuch should be axially out of balance by that much and that should make an ungodly amount of vibration when you start it.
#13 | |
Drives: Scion frs
I swapped the clutch while the engine was outside of the car, I don’t think I noticed if the flywheel was flat against it or not Sent from my iPhone using Tapatalk |
#14 | |
Drives: Limited BRZ
Nope, the pin was still there. Let me see if I can dig pics.
| Starting issue after building engine | sid94 | Forced Induction | 51 | 04-28-2018 02:59 PM |
| Heating catalyst without starting engine? | BRZyJ | Engine, Exhaust, Transmission | 9 | 08-23-2017 02:42 PM |
| Low hum after starting the engine (BRZ MY 2017) | spike021 | BRZ First-Gen (2012+) — General Topics | 15 | 03-22-2017 11:55 AM |
| Engine not starting | S84kam | Issues | Warranty | Recalls / TSB | 26 | 08-30-2016 07:43 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 03:45 PM |
