Old 08-21-2017, 10:29 PM   #1
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Heating catalyst without starting engine?
I had this happen the other day but I can't replicate it. I had my head unit out and was messing around with some Torque gauges after I put it back and I noticed the cat in the front pipe was warming up, pretty quickly. I let it get to ~450° and started the engine, nice and (fairly) quiet.
I figured I'd stumbled on a way to avoid the loud cold start without messing with the tune, but it won't do it again.
Was it just a weird fluke or did I do some sequence of things I can't remember? The temperature started going up as soon as ACC was on, I don't remember doing anything out of the ordinary before that.
BRZyJ is offline   Reply With Quote
Old 08-22-2017, 07:18 PM   #2
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Cat is warmed up by exhaust gases, so if car is not running what is heating it?
Ernest72 is offline   Reply With Quote
Old 08-22-2017, 08:03 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How can the front cat temp be detected if there's no thermoprobe?
Old 08-22-2017, 08:48 PM   #4
BRZyJ
BRZyJ's Avatar
I dunno...a google search yields a bunch of results for electrically heated catalysts so I guess such a thing exists...never heard of it myself.
Dunno that either...just happened to see that PID as I was messing around
Old 08-22-2017, 10:51 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
I remember reading somewhere on the forum that there is a calculation the ECU does to approximate cat temps. There may be a way you fooled the calculation...
1974 TA22 Celica
2013 86 GT
Old 08-23-2017, 12:32 AM   #6
humfrz
I don't know how that happened ....... but, I sure hope it doesn't happen again and burn your car up ......
humfrz
Old 08-23-2017, 01:34 AM   #7
BRZyJ
BRZyJ's Avatar
Thx...I dug around and did find that mentioned a couple of times. Tried to get it to do it again a few times this evening, but nope. :/
:O lol... now I kinda wish I'd let it keep going before starting it to see if it went past the normal range, which seems be mid 800s°F. I'll either forget about it or waste a ton of time trying to reproduce it...meh...
Old 08-23-2017, 06:07 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
There's an oxygen sensor heater. Look up all the P0031 CEL's that have posts on this forum. I think the ignition was in the on position instead of ACC and that allowed the O2 sensor to heat itself up to temp. You're really stressing your battery though, not good.
Old 08-23-2017, 06:52 AM   #9
steve99
The 02 sensor in these cars has a heater circuit to regulate temp of sensor.
Buy measuring the current in the heater circuit the ecu can approximate the exhaust/cat temps
the ecu regulates the temp of the 02 sensor
You can read the parameter via Techstream or OBD software like Torque.
http://www.romraider.com/forum/viewt...t=8134&start=0
Old 08-23-2017, 02:42 PM   #10
BRZyJ
BRZyJ's Avatar
Huh...so the O2 sensor heater had to be heating the cat. You are correct, it was ON not ACC, my mistake. After reconnecting the head unit I messed with some Torque displays with ACC on, then switched to ON which is when the temperature immediately began climbing. Hasn't done it since...weird. Battery is probably due to be replaced soon either way...still on the original.
I see...I saw in the other threads that PID was a calculated value, but not where it came from, thx. Well, hopefully it's not a symptom of an impending failure.
Low hum after starting the engine (BRZ MY 2017) spike021 BRZ First-Gen (2012+) — General Topics 15 03-22-2017 11:55 AM
Engine not starting S84kam Issues | Warranty | Recalls / TSB 26 08-30-2016 07:43 AM
Catalyst's Ace FRS CatalystPLUR Member's Car Journals 1 06-02-2016 03:42 PM
[FS:US] [FS:US] Cisco Catalyst 3750 WS-C3750V2-48PS-E Got3n Miscellaneous 1 01-11-2013 01:55 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
