Old 04-25-2019, 05:37 PM   #1
AD55
Drives: 2014 BRZ
Cusco Intake Pipe
I was at a garage sale the other day and the guy had a number of BRZ aftermarket parts for sale that he had removed before selling the car.
One was a Cusco Intake Pipe replacement. It was supposed to be an exact replacement for the stock intake. The only real difference was that it was a chrome plated metal piece that had a fitting where you could screw in a plug to block off the sound pipe thingy. It also had blue flex connectors at the throttle body and air box connectors. I assumed it provided no real performance gain, and was probably just a cosmetic piece for the engine compartment.
I noticed there was a line on the installation sheet that stated the part was designed for use in Japan only and it must not be used in other countries. Actually they were the only words on the sheet written in english.
Was wondering if anyone knew why it would state this. Thought maybe it was a fitment issue with BRZ's not sold in Japan, but the guy said it installed perfectly and did not seem to cause any problem. I'm not really thinking about buying it, just curious about the statement in the instructions.
AD55 is offline   Reply With Quote
Old 04-25-2019, 05:42 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
I would assume it's the same as "offroad use only".
Start here.
https://ww2.arb.ca.gov/homepage
maslin is offline   Reply With Quote
Old 04-25-2019, 06:36 PM   #3
kch
Senior Misanthrope
kch's Avatar
Regulatory/tax issue of some sort.
Old 04-25-2019, 07:00 PM   #4
tomm.brz
Drives: brz 2017 hksv2
also enjoy the heat soaking :P
Old 04-25-2019, 07:49 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Start here.
Yes, exactly this.
Modification of specific sections of the intake and exhaust with aftermarket parts is not legal per CARB, unless the part has a CARB certification.
Why? A large number of cars sold to US market are qualified in accordance to and meet CARB emission standards.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
maslin (04-25-2019)
Old 04-27-2019, 04:01 AM   #6
AD55
Drives: 2014 BRZ
Originally Posted by EndlessAzure View Post
Yes, exactly this.
You are probably correct. Just seems strange they didn't word it differently.
"Not for use in the U.S." would seem more appropriate than "designed for use in Japan and must not be used in any other country."
But then I'm not a Japanese to English translator so what do I know?
Cusco Intake Pipe '13-'16 norcalpb Engine, Exhaust, Bolt-Ons 6 06-10-2018 02:16 PM
Cusco intake pipe...did I install this correctly? Trmx2 Engine, Exhaust, Transmission 14 08-28-2017 04:25 PM
MXP UEL, over pipe, Supertek Intake intake pipe / filter runnin9z Engine, Exhaust, Bolt-Ons 4 09-20-2015 10:59 PM
Perrin Cold air intake, Cusco air suction pipe JPDinCV21 Engine, Exhaust, Transmission 1 07-27-2015 03:31 PM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 02:44 PM
