Old 04-24-2019, 08:28 PM   #1
Open Loop
2013 FR-S Whiteout / SSC
I need to make brake pad adjustment.
Hi everyone. I have a brake pad question: I have been running Carbotech XP8 front and my autocross pads (Ferodo DS2500) on the rear when on track for the past year or so. This is my second full year doing HPDE and TT. Tonight at a TNiA at Pitt Race (which is known to be hard on brakes) I started to get some fade, and it was annoying. This is really the first time I have noticed it with this setup. (FWIW I changed the fluid a few weeks ago, and did a HPDE weekend at Putnam two weeks ago with no issue). I think I need to "go up one notch" on the track pad scale. I am interested in your thoughts. Thank you!
Open Loop is offline   Reply With Quote
Old 04-24-2019, 09:08 PM   #2
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
If you like Ferodo, the DS1.11 in the fronts work great. Otherwise, just up the Carbotech compound and try an XP10 or XP12. All of these are going to make more noise and dust than what you've got, the XP10 isn't too much worse on noise and dust than the XP8's but they might not be enough pad for you.
You've got enough rear pad for just about any application with the DS2500.
14stu is online now   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Open Loop (04-24-2019)
Old 04-24-2019, 09:57 PM   #3
Open Loop
Thank you. I am going with the XP10's.
Old 04-25-2019, 08:30 AM   #4
M0nk3y
@14stu, are you aware if the DS1.11s are a direct swap on an existing rotor hat if you're running DS2500s?
Kyle H. - #89 STX
Old 04-25-2019, 10:12 AM   #5
14stu
14stu's Avatar
They are, I went straight from the DS2500 to the DS1.11 without any issues. I did spray the rotors down with brake cleaner and bedded the new pads though. The DSUNO work similarly but I preferred the DS1.11 to the DSUNO's.
GLoc/Carbotech are the last set of pads I'll be testing out once my DSUNO's wear out (they are wearing well, which is nice but they aren't my favorite pads since I like more initial bite and they are a less grabby than the DS1.11's). I've got a set of GLoc R10 I'm trying next (I'm running GLoc's in the rear and liking them).
I've been experimenting the last 2 years with pads and the DS1.11's have been my favorite so far.
M0nk3y (04-25-2019)
Dealer parking-brake adjustment fail. chad1376 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-14-2017 10:45 AM
Emergency brake adjustment? F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2013 10:59 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Brake switch adjustment ? photomike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-20-2013 01:49 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
