Old 04-22-2019, 01:54 PM   #1
Enterthe
Do I need hub centering rings for my new wheels?
I’ve searched around already but can’t find a solid source for information. I purchased a set of Enkei PF05s which have a 75mm center bore. Other wheels I have purchased in the past have come with the centering rings but these do not, and I’m not finding centering rings in the exact 75mm->56.1mm size I need. TIA!
Enterthe is offline   Reply With Quote
Old 04-22-2019, 02:05 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You don't NEED them, as the lug nuts are tapered to center the wheels. I would suggest them if you're doing anything other than daily driving (i.e. AutoX, Track days, etc.), or for peace of mind.
http://www.ft86club.com/forums/showthread.php?t=14018
https://www.newprovisionsracing.com/...b-centric-ring
https://www.ebay.com/itm/HUB-CENTRIC...-/292186400431
BigTuna is offline   Reply With Quote
Old 04-22-2019, 02:10 PM   #3
HaXx
Drives: jrsc_brz
I literally just put brand new ts10 rims on yesterday, and for some reason I had to remove 3 of the hub rings for the wheels to go on, and I'm positive I had the correct size rings. only one wheel fit on with a ring. you might as well get them, if they dont go on with them, oh well, if they do, even better.
HaXx is offline   Reply With Quote
Old 04-22-2019, 03:12 PM   #4
Tokay444
Anti stance.
Tokay444's Avatar
Yes.
Old 04-22-2019, 04:23 PM   #5
JoeC
Drives: Subaru BRZ Limited
You don't need them but they certainly make wheel\tire swaps a lot faster. I don't have them on my daily wheels but I do on my track wheels because they're so much more convenient when rotating wheels at the track. Whenever I put my daily wheels on (at the end of a track event) I just make sure to be very careful when snugging up the lugs to allow the wheel to center up.
JoeC is offline   Reply With Quote
Old 04-22-2019, 04:26 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Need? - no.
However, if your wheels are on/off relatively often they are a quality of life luxury as it makes putting your wheels on easier and your lug nuts have less centering work to do.
PRO86 | STL | LuckyDog
Old 04-22-2019, 05:42 PM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes you do. The lugs - while self centering and tapered - locate on a threaded feature, which have way looser tolerances than that hub surface.
Old 04-22-2019, 06:04 PM   #8
Enterthe
Thanks so much for the info everyone, I went ahead and ordered some.
Old 04-22-2019, 07:53 PM   #9
JoeC
on one stud yes, but snugging all 5 down together centers the wheel it right up. it's a little slower to install but I promise, it works.
Old 04-22-2019, 08:00 PM   #10
You do not.
They are nice for taking stress off of your lugs and studs on initial tightening.
Old 04-24-2019, 07:29 PM   #11
Feistyfrog
Drives: Toyota 86 2019
You don't need it but you should unless you are the only person who will remove/install your wheels and you know what you're doing.
I just got my new 86 ten days ago and the dealership took care of installing my own wheels prior to the delivery. They didn't want my rings because, "they are useless".
I ended up having huge vibrations over 100km/h because they screwed up the install (no pun intended). No big deal but it can't happen with some rings.
They are so cheap, it's a no brainer...
Feistyfrog is offline   Reply With Quote
Old 04-25-2019, 10:44 AM   #12
wparsons
wparsons's Avatar
Even with rings or hubcentric wheels you should be doing that since they can be off center rotationally still.
flickr
Centering caps for the TC105N from Gruppe-s cjd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 11-09-2021 03:57 AM
Do you need hubcentric rings on aftermarket wheels? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 36 01-18-2017 06:08 PM
Priced 2 Sell 17x9 Gold RPF1s (4) ET45 *wheels only* with Hubcentric rings Lithium Wheels and Tires 12 02-07-2016 05:32 PM
centering rings necessary? bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 03-24-2014 03:46 PM
Purchasing a set of Work Wheels today...what's this about hub centric rings? stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-28-2013 02:50 AM
