Old 02-23-2019, 03:40 AM   #1
supercharged680
Drives: 2015 GT3 , 2018 BRZ , 2007 S2K
Suspension setup for flat track
Hi guys, new to the forum but not to the tracking/racing world.
So i bought a 2018 BRZ lately and it is bone stock for now other than headers and OFT. Would like to go for some modifications for the very flat and boring tracks we have here in Dubai, "Yas Marina and Autodrome Circuit"
A test that i did with my 991.1 GT3 on Yas Marina last night was test on stiff suspension i did a 2:23 after softening the suspension with press of a button that car had better traction out of the corners and felt more planted, yes it rolled a bit more but it gained much more traction, i managed to do a 2:21! almost 1.5 to 1.7 seconds faster.
Which is why i came to think about what i should do with my BRZ i do not need to go overkill with coilovers , maybe springs and swaybars would be sufficient? I would do some testing and try different things but then the season is about to end in May so i would like to get something running for now atleast..
So far in the plan is brake pads , lines and fluid + FPF1 17x9 wheels , various stiffer bushings "recommendations on brands and parts would be great"
Thanks guys!
supercharged680 is offline   Reply With Quote
Old 02-23-2019, 07:03 AM   #2
scottman
scottman's Avatar
Drives: 13 mt fr-s
In my opinion.
Pads and fluid only, lines aren't necessary.
Also, Rear subframe bushing inserts helped lots. I went with Whitelines.
scottman is offline   Reply With Quote
Old 02-23-2019, 04:58 PM   #3
wparsons
wparsons's Avatar
What exactly are you trying to "fix" with the modifications? What kind of tires do you plan to run?
flickr
Old 02-23-2019, 05:10 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
That's a big one.
The compound you are looking to run will be a large factor in what suspension to look at.
Old 02-23-2019, 10:52 PM   #5
Aluma007
Drives: 2017 Brz
bilstein b8's with rce tarmacs and group N strut mounts? I believe the springs are 5k which are almost as stiff as coilovers so they should be good for any of the street rubber available.
Aluma007 is offline   Reply With Quote
Old 02-24-2019, 02:07 AM   #6
supercharged680
Thanks for the reply, I still do not know which tire i am going to run, probably Nankang AR1 , Toyo R888 or similar. Maybe even try the Pilot sport 4s , problem is here in Dubai its very difficult to find tires so i have to take whatever is available. Worst case will be ordering online which is super expensive
Thanks guys.
Old 02-24-2019, 04:15 AM   #7
x808drifter
LMGTFY
Thanks guys.
More what compound type than what actual tire model is what we were wondering.
Those with more first hand experience can definitely chime in with what you've provided.
Old 02-24-2019, 08:27 AM   #8
supercharged680
Semi-slick / high performance tire.
Thanks.
Old 02-24-2019, 11:51 AM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Gonna put on aero?
Old 03-05-2019, 05:23 AM   #10
supercharged680
Originally Posted by jsimon7777 View Post
Gonna put on aero?
No, we have very long straights, i can use all the power i need.
planning on staying N/A too.
Old 03-05-2019, 03:42 PM   #11
EAGLE5
Dismember
EAGLE5's Avatar
RCE Tarmac or equivalent. CSG has good stuff too. Why not spring for the good stuff? Sway bars are more for tuning balance. Oil/air (not oil/water) cooler from pretty much anybody. AP Sprint brakes.
Old 03-05-2019, 05:21 PM   #12
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Thanks guys!
We've setup a few cars for QTCC and have some datalogs from those racers including the one who won the QTCC 4 years in a row. Let us know what your actual goal is for driving. Will you be competing?
CounterSpace Garage is offline   Reply With Quote
Old 03-06-2019, 01:12 PM   #13
supercharged680
That is great!
Competing will be a few times a year in the 2L N/A category , the car will see a few track days a year and street driven too "not daily"
Thanks.
Old 03-06-2019, 02:23 PM   #14
Thanks guys!
Remember your .1 GT3 is pushy; reducing the damping by taking the car out of chassis sport enhances weight transfer rotation, likely resulting in better corner exits. On smooth tracks like yours, having critical damping is not as important as maximizing average speed.
brz, camber bolt, dubai, suspension, sway bar
Ideal Suspension Setup for DD and Mild Track Use? Lust Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-22-2022 09:37 AM
Suspension setup hpde_addict Tracking / Autocross / HPDE / Drifting 12 11-17-2017 04:26 PM
Suspension Setup? ImAdopted Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2017 03:56 AM
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 08:36 PM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 03:03 PM
