Northern California NorCal
Old 04-11-2019, 12:54 PM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
how many gallons of E85 for...
I live in the North San Jose area, so how many gallons of E85 I need to bring to have full 5 sessions Thunder hill and back?
Does anyone have this experience?
Thanks
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
Old 04-12-2019, 01:07 AM   #2
sfruski
Drives: Many
Depends on how fast you are.
I run a supercharged FRS. The car goes though 1 gallon of 91oct every 5 minutes of track time, 12 gallons an hour.
On the extreme end E85 can use 30% more fuel. Worst case would be 16 gallons an hour of track time.
You will probably use between 20 and 27 gallons of fuel for five 20min sessions. Less, possibly a lot less, if you are new to driving on the track.
You can calculate your freeway mileage requirements.
sfruski is offline   Reply With Quote
Old 04-12-2019, 12:02 PM   #3
Xevuhtess7
I fill up my car and 3 5-gallon jugs at "Oliver Gas" on Oliver Rd in Fairfield. That is enough to comfortably drive to T-hill, 5 sessions, and back to fill up at the same station on my way back to the Peninsula. I am NA on an OFT E85 tune
Xevuhtess7 is offline   Reply With Quote
Old 04-12-2019, 01:17 PM   #4
FR-Sky
FR-Sky's Avatar
In that case, I 'll think that 15 gallons will probably safer for me since I live a little bit down south, North San Jose.
5 Gallons + left over for track.
10 gallons to go home.
Thanks
IG: @rearwheelclub
Old 04-12-2019, 07:41 PM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If you fill up at the Arco in Woodland on your way there and back you should be fine with 5 extra gallons. But I would take 10 just in case.
This is for NA cars. FI I have no clue lol
Old 04-12-2019, 08:18 PM   #6
FR-Sky
FR-Sky's Avatar
There are 3 ARCO in Woodland, do you know which one by any chance?
I couldn't see on google map lol
IG: @rearwheelclub
Old 04-12-2019, 08:30 PM   #7
Xevuhtess7
I use this site to figure out where the e85 stations are. It's kind of buggy though... but it works. Oh and some of the listings don't exist/closed, so do a little background research before driving there on empty
http://www.e85vehicles.com/e85-stati...alifornia.html
Old 04-14-2019, 03:21 AM   #8
finch1750
finch1750's Avatar
450 County Rd 102
Woodland, CA 95776
Old 04-27-2019, 07:52 PM   #9
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Just fyi, I can perfectly fit six of the five gallon cans in my trunk, which has the OEM rubber liner. I bought them at a local Friedman’s.
Old 04-28-2019, 03:07 AM   #10
FR-Sky
FR-Sky's Avatar
Dam, thats alot of gallons. But i think 4 of five gallons will work to go to Thunderhill and back
IG: @rearwheelclub
Old 04-28-2019, 03:14 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I did this before but it was years ago. 15-20 gallons should do you. You can always fill at the not-so-far away E85 station to make sure you'll make it.
Out of gas at only 9 gallons? Whoodoo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 09-24-2018 09:29 PM
Out of fuel with 2 gallons in the tank Simisimi Issues | Warranty | Recalls / TSB 31 06-18-2015 03:30 PM
