Old 08-25-2018, 08:43 AM   #1
Whoodoo
Drives: '15 BRZ, Vortech supercharger
Out of gas at only 9 gallons?
I took a long road trip recently and the car started acting like it was out of gas after only 270 miles. The fuel gauge was at the 1/4 mark. Luckily I barely made it to a gas station, but it only took just over 9 gallons before the pump shut off.
As I was chugging into the gas station, the check engine light came on, but after two short trips around town, the light went off.
Has anyone had similar issues?
Whoodoo is offline   Reply With Quote
Old 08-25-2018, 11:24 AM   #2
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Mine was a few mm away from the empty line and the gas light went on the other day. I'd say almost in between the 1/4 mark and empty mark. Im wondering how many gallons are left when the light comes on. It may come on sooner for these cars since its such a small tank
SuperTom is offline   Reply With Quote
Old 08-25-2018, 04:33 PM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've found my light turns on after 10 gallons are used up from full, so 3.2 gallon left in the tank with the gas light.
Old 08-25-2018, 06:08 PM   #4
gravitylover
My light goes on around 11 gallons used.
Old 08-25-2018, 06:26 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
You had plenty of fuel.
The check-engine light is not the low-fuel light.
There are a bajillion things that can go wrong which feel like the car is running out of gas because the end result is the same. The engine stumbles.
Check to see if a trouble code was stored. If you have one, share it with us.
Old 08-25-2018, 07:07 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
What? You had a check engine light? Not a low fuel light, and your profile shows you have a vortech supercharger. Time to take it to the tuner or wherever the install was done and have them run the codes and check the tune. Hopefully the code is still there, or you can reproduce it under the same conditions
Old 08-26-2018, 12:42 AM   #7
Ultramaroon
not playing cards
I don't see it working out for OP in the long run.
Old 08-26-2018, 01:57 AM   #8
FRSBRZGT86FAN
How so? The fact that the vortech is a bad supercharger for our cars that was plagued with porblems or his issues diagnosing problems or confusion with the CEL and low fuel light lmao...
Old 08-26-2018, 02:39 AM   #9
Ultramaroon
not playing cards
More the latter and that he didn't think to mention his mods in the OP. Shows a lack of appreciation for the added complexity and risk.
Old 08-26-2018, 01:39 PM   #10
Whoodoo
I didn’t mention any of my mods because I am very skeptical that it has anything to do with the supercharger or the tune. If there has been similar issues with unmodified cars, then that would narrow things down a ton.
Thanks for the input so far. I’ll get the codes read and report back later today.
Old 08-26-2018, 02:12 PM   #11
Ultramaroon
not playing cards
Ah, gotcha. Well, it's always best to put it all out there up front and let us sort it out. Speaking for myself, I get kinda grumpy when I learn that potentially valuable info had been omitted.
But I keep coming back so I guess I can only blame myself.
Let us know if your ECU stored any codes.
Old 08-27-2018, 11:30 AM   #12
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
I have similar issues. Stumbling and hesitation around 1/4 tank. No low fuel light and "lean" related codes if I push it. It will eventually refuse to start just as if it was truly out of gas. Fill up is as expected for 1/4 tank left...about 9-10 gallons.
I believe it has to do with the siphon "jet" device that pulls fuel from the right (passenger) side of the tank to the left (drivers) side where the fuel pump is. You can sort of verify this by taking a hard right hand turn to slosh fuel from right to left and see if you get more miles from the tank.
I plan on pulling the pump assembly to make sure it's all assembled properly because I have had it out to install a higher flow fuel pump in the past. The siphon tube is the only hose that that connects to the assembly (at the bottom) inside the tank.
PhyrraM is offline   Reply With Quote
Old 08-27-2018, 01:30 PM   #13
SuperTom
SuperTom's Avatar
Ill admit I breezed through his comment and didn't realize it was a check engine light and not a gas light.
So when you guys fill back up with gas the check engine light goes away??
Old 08-27-2018, 01:41 PM   #14
Ultramaroon
not playing cards
Yes but then my TPMS starts flashing so I just leave the cap off.
Out of fuel with 2 gallons in the tank Simisimi Issues | Warranty | Recalls / TSB 31 06-18-2015 03:30 PM
