Drives: 14 FRS Monogram, 05 Mazdasped Miata
Eek! Oil leak
I found a small puddle of oil on the garage floor today. This is what I found when I dropped the pan. Driver side.) I guess I didn't get a pic after I cleaned it up, but everything looked pretty normal. I'll watch it for a week or so, but I don't expect it to fix itself. Anyone have an idea how much trouble I'm in? Warranty expired three weeks ago!
Drives: 2013 WRB BRZ
Probably just the front timing cover leaking. Fairly common issue. But I'm not sure how much the fix is.
Sent from my SM-G930V using Tapatalk
Mine had the same leak before I took it on for the recall. Upon reassembly, they reseal it and I haven't had it leak since. It had been happening for maybe 6 months, however, I never saw any measurable oil loss. Maybe just keep an eye on it, check the oil level every once in a while and monitor if it changes.
Not that common an issue on a post 13 but depends on when your 14 was built I guess.
Here are the common leaks and how to fix them. http://www.ft86club.com/forums/attac...1&d=1413834741
#6 | |
Well you don't get much earlier a 14 than that.
Airborne at your service
Drives: '17 BRZ Series.Yellow
I noticed recently mine has a little on the driver side.
Oh, just put a pan under the car on the garage floor and add oil to the crankcase every now and then.
Well, it's what some of us used to do - ![]() humfrz |
#10 |
#11 |
What about cleaning the site, and applying some high temp RTV sealant over it?
#12 |
#13 | |
| Gas Leak? | Fuco | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 10-07-2022 09:40 AM |
| Oil leak help please | TorontoNat | Engine, Exhaust, Transmission | 1 | 12-26-2018 01:36 PM |
| Oil Leak? | Tofu-86 | Forced Induction | 3 | 09-23-2016 03:47 AM |
| Yet another oil leak.... | Astroboy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 09-24-2015 01:02 AM |
| Oil leak. | ohnoitsthefuzz | Issues | Warranty | Recalls / TSB | 2 | 03-23-2015 01:31 AM |
