Old 04-10-2019, 02:29 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Eek! Oil leak
I found a small puddle of oil on the garage floor today. This is what I found when I dropped the pan. Driver side.) I guess I didn't get a pic after I cleaned it up, but everything looked pretty normal. I'll watch it for a week or so, but I don't expect it to fix itself. Anyone have an idea how much trouble I'm in? Warranty expired three weeks ago!
Qwimby1 is offline   Reply With Quote
Old 04-10-2019, 02:32 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Probably just the front timing cover leaking. Fairly common issue. But I'm not sure how much the fix is.
Sent from my SM-G930V using Tapatalk
BigTuna is offline   Reply With Quote
Old 04-10-2019, 02:50 PM   #3
Qwimby1
You may have just made my day!
Old 04-10-2019, 02:57 PM   #4
BigTuna
BigTuna's Avatar
Mine had the same leak before I took it on for the recall. Upon reassembly, they reseal it and I haven't had it leak since. It had been happening for maybe 6 months, however, I never saw any measurable oil loss. Maybe just keep an eye on it, check the oil level every once in a while and monitor if it changes.
Old 04-10-2019, 03:03 PM   #5
Not that common an issue on a post 13 but depends on when your 14 was built I guess.
Here are the common leaks and how to fix them.
http://www.ft86club.com/forums/attac...1&d=1413834741
Old 04-10-2019, 03:50 PM   #6
Qwimby1
Very helpful. Thank you. Build date 1-14..
Old 04-10-2019, 04:04 PM   #7
Well you don't get much earlier a 14 than that.
Old 04-10-2019, 04:46 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I noticed recently mine has a little on the driver side.
MS, CSCS, TSAC-F, CPT
Old 04-10-2019, 09:27 PM   #9
Oh, just put a pan under the car on the garage floor and add oil to the crankcase every now and then.
Well, it's what some of us used to do -
Old 04-11-2019, 11:03 AM   #10
Qwimby1
My wrench tells me it could take 8-9 hours to fix! Seems like an awful lot. It's a job I couldn't take on.
Old 04-11-2019, 11:10 AM   #11
weederr33
weederr33's Avatar
What about cleaning the site, and applying some high temp RTV sealant over it?
Old 04-11-2019, 12:46 PM   #12
BigTuna
BigTuna's Avatar
https://www.ft86club.com/forums/show...5&postcount=24
Old 04-11-2019, 03:40 PM   #13
Qwimby1
Looks like a good way to go. I'll try it.
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil leak help please TorontoNat Engine, Exhaust, Transmission 1 12-26-2018 01:36 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
Yet another oil leak.... Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-24-2015 01:02 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
