Old 04-10-2019, 01:03 AM   #1
juniorrr
Drives: Scion Frs
Really need Help/Advice to Fix this Exhaust Leak..
So just recently I installed a HKS Front pipe to my exhaust set up.. And the front pipe is leaking despite using grimspeed gaskets, redoing it 3 times and then sending it to a shop and it’s still leaking... Leak is located where the frontpipe meets the overpipe.
During cold start is the time when it releases a little bit of exhaust fluids and then all of a sudden it stop.. but you still hear the air escaping Faintly at idle and mostly when driving it around when the sound rebounds off something.
Some ppl told me double gasket on it somebody else said use gasket sealer with the grimspeed gasket also in there. I’m seriously looking for your guys help/advice on what I should do next. Thank you I appreciate it!
juniorrr is offline   Reply With Quote
Old 04-10-2019, 01:45 AM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Get a new exhaust. I've had the same issue and it did get better with another exhaust. Maybe someone will have a better answer.
Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 04-10-2019, 01:48 AM   #3
juniorrr
Drives: Scion Frs
New Exhaust o.O I have a Perrin Resonated 2.5 CBE. It’s a really really good CBE A lot of R&D was put into and plus it cost me like 1.1k How would that fix it though? The exhaust leak is where the front pipe meets the Overpipe.
Old 04-10-2019, 02:33 AM   #4
Strife26
Strife26's Avatar
If it's so good why is it leaking?
Was just a suggestion in case it wasn't great. Fixed my issues but I did have a cheap exhaust sooo.
I considered double gasket but didnt seem like it would work. Maybe try it.
Old 04-10-2019, 02:40 AM   #5
juniorrr
Drives: Scion Frs
You need to reread my post... It’s my Front Pipe to the Overpipe that’s Leaking not the CBE. I just got a new front pipe. But yeah I’m wondering if any one has anything they’ve tried to fix this issue
Old 04-10-2019, 02:45 AM   #6
humfrz
It sounds like you have given it a good go.
I'd suggest you take it to another muffler shop, tell them you have an exhaust leak and have them fix it, even if they have to weld it.
humfrz
Old 04-10-2019, 03:15 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check the flanges to make sure they are flat and not warped. They may need some touch up to get them to seal.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
guybo (04-11-2019)
Old 04-10-2019, 03:33 AM   #8
Strife26
Strife26's Avatar
You could try threadlocker if you haven't. I haven't yet, but my bolts seem to be fairly loose every time I take em apart, coming off the headers.
Unless someone has a reason not to...
Old 04-10-2019, 03:40 AM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A crack or mating surfaces that aren't flat or square. I have a Borla EL that has been rewelded and reworked many times by previous owners. It finally cracked on me. Aftermarket stuff is often shit.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Tcoat (04-10-2019), Ultramaroon (04-10-2019)
Old 04-10-2019, 12:32 PM   #10
Exhaust fluids?
Old 04-10-2019, 02:27 PM   #11
juniorrr
Drives: Scion Frs
Well when I first saw the the exhaust flanges they looked pretty good. It’s feom HKS which I have never heard anything bad about them with their front pipes. But if I did have to go back and grind it that little grind wouldn’t be more of a cause for a leak since the pipe will be slightly shorter?
Exhaust fluids?
Yeah the fluids that come out the exhaust gas and idk what else it is tbh lol
Anyone else know if I put exhaust sealant maker around the connection point if it could seal it up? That way I don’t have to go back and unscrew everything and 4th time?
Old 04-10-2019, 02:31 PM   #12
Water.
There is enough play in the system that grinding it smooth will not make it too short. I am with the other guys that say there is a flange issue and if it was as bad as you say the gasket will not make up for it. Pull it and clean it up is the best.
Sealant placed on top will just blow out. Believe me I have done it enough times with "classic" cars.
DarkPira7e (04-10-2019), EAGLE5 (04-10-2019)
Old 04-10-2019, 08:46 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
The exhaust is on rubbery hangars that can move several inches in different directions. There will be absolutely no issue with grinding.
Old 04-10-2019, 10:19 PM   #14
humfrz
Water.
Tcoat, inspecting his work, back-in-the-day -
humfrz
Tcoat (04-11-2019)
Small Leak, need advice. AbductedCasper Engine, Exhaust, Transmission 5 10-03-2018 10:49 PM
Possible exhaust leak? dar3d3vil Engine, Exhaust, Transmission 10 02-21-2016 08:45 PM
Exhaust leak? Jman1759 Engine, Exhaust, Transmission 4 11-30-2014 12:11 AM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 02:08 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 01:59 PM
