Old 04-01-2019, 11:07 AM   #1
Nystix
low idle
So I bought my 13 FRS wrecked in the front end and fixed it up. shortly after driving it for a week the idle would jump all over the place. its an automatic and would stall at red lights with the idle dipping very low. I purchased an oft v2 and installed the stage 1 tune. seeing as the car is just stock. The tune made it run great for a few months. No more idle dip or stalling. Then about a week ago it started back again. I even tried to tune the car again, but idle is still dipping very low. Any ideas on what could be going on? I have tried contacting Toyota but they had no answers
Nystix is offline   Reply With Quote
Old 04-01-2019, 11:11 AM   #2
The fix for this is a flash for the TCM so not sure you can do it with OFT.
See the attached TSB
http://www.ft86club.com/forums/attac...1&d=1486956417
Old 04-01-2019, 11:18 AM   #3
Nystix
Thank you ill ask Toyota about that. I was telling them what was going on but they didnt know what to do. Also mine is a 2013 not 15-16 I guess they all had that problem anyways? It says that it happens in park and neutral, but mine does it in drive too.
Old 04-01-2019, 11:23 AM   #4
People have had it applied ti the 13s and it seemed to help.
There is this one as well but you don't seem to have the other symptoms.
http://www.ft86club.com/forums/attac...1&d=1375302652
Old 04-01-2019, 11:29 AM   #5
Nystix
That makes me wonder too because I did have to replace both right side cam sensors due to the plugs being broke in the wreck
Old 04-01-2019, 11:37 AM   #6
Gunman
Drives: 2019 Mazda Miata RF
Could be the cam sprocket, and it just hasn't gotten to the CEL point yet.
http://www.ft86club.com/forums/showthread.php?t=15577
Gunman is offline   Reply With Quote
Idle dip but going FI mscamp02 Forced Induction 16 11-09-2015 03:16 PM
Idle at 4 psi? LS1M Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-18-2015 12:01 PM
K&N idle dip Dominus Engine, Exhaust, Transmission 7 01-28-2015 10:17 PM
Low idle? MadeInSweden Issues | Warranty | Recalls / TSB 2 12-09-2014 03:15 AM
Odd idle jbixel Issues | Warranty | Recalls / TSB 2 11-02-2013 08:35 AM
