Old 01-28-2015, 02:04 AM   #1
Dominus
Dominus's Avatar
Drives: 2013 BRZ Limited
K&N idle dip
I have a K&N intake (not my first choice but it came with the car.) Personally I dont think it looks good and the design looks more of a warm air intake then a cold air since the box is hardly sealed.
However, i dont have the stock and dont feel its worth wasting a $300 intake setup just because of the idle dip i have.
I know there is a TSB on the idle dip but Subaru states that the "tech verified high idle due to K&N cone filter". I think this is bull as the system should be able to learn the subtle intake improvements but they refused to reflash the system to fix the idle dip.
So my question for you guys is: should a new intake cause the dip/high rpm?I'm seeing the 750rpm drop to 500 then back, sometimes reaching 1000 for a short while. Or are they full of crap and just trying to get out of doing the work? I've already had it with this dealership and plan on going to a different one if I have to.
Thanks,
Dominus is offline   Reply With Quote
Old 01-28-2015, 02:26 AM   #2
breadcrumbz
breadcrumbz's Avatar
Drives: 2013 FR-S 6MT
Toyota didnt want to flash the ecu update for my car either because I have a Zeta inlet tube, even though I had the idle dip issue at stop lights with the stock intake. Time to invest in an OFT..
breadcrumbz is offline   Reply With Quote
Old 01-28-2015, 02:54 AM   #3
Dominus
Dominus's Avatar
Yeah I've been looking into that if not RomRaider at least, it just bothers me to spend more money on something that they can fix. I can live a little longer without launch control, 10+HP, and the torque dip if i could just get this Idle dip fixed for now
Old 01-28-2015, 03:10 AM   #4
steve99
Does idle dip happen with stock intake ?
If yes put stock intake on and get dealer to reflash
If no then its probably caused by the K&N intake upsetting the MAF Mass Air flow scaling and hence your running large fuel trims and incorrect AFR. It can be fixed by rescaling maf sensor to suit intake.
Intakes make sod all power on NA cars.
have a read here http://www.ft86club.com/forums/showthread.php?t=81493 if you planning future mods
Old 01-28-2015, 08:27 AM   #5
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Unfortunately OP doesn't have the stock intake system. He bought the car with the K&N system already installed.
Rabbit of Caerbonnog is offline   Reply With Quote
Old 01-28-2015, 07:02 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
OP, the OEM reflash may not fix your idle dip if it is a maf scaling issue.
1974 TA22 Celica
2013 86 GT
Old 01-28-2015, 07:19 PM   #7
SurfAndSand
8SiX
Drives: FRS 10series
Did you check for loose fittings and such? I had some idling problems, and it turned out to be just some loose fittings causing havoc with the MAF. I tightened everything up, and idle problems went away.
SurfAndSand is offline   Reply With Quote
Old 01-28-2015, 10:17 PM   #8
Dominus
Dominus's Avatar
they are tight as far as i could tell but its cold and snowing and i dont have a garage to take the wrenches to it. There only seems to be the clamp over the intake and the two bolts holding the MAF that would cause any trouble. am i missing something?
what is this scaling that needs done? would the MAF maybe need spacers or something to correct the issue?
Edit: nevermind, a quick search on scaling leads me back to needing a tune.
Thanks
Idle dip yomny Software Tuning 38 06-14-2016 05:54 PM
Low idle? MadeInSweden Issues | Warranty | Recalls / TSB 2 12-09-2014 03:15 AM
AFR @ Idle woode Forced Induction 12 01-19-2014 08:38 PM
Odd idle jbixel Issues | Warranty | Recalls / TSB 2 11-02-2013 08:35 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
