Old 04-01-2019, 02:20 AM   #1
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
HKS Legamax Resonator Delete? Edit: electronic cutout valve?
Ever since I went turbo this exhaust has become too quiet.
Would deleting the resonator from the mid pipe give me a bit more sound? Thanks!
Edit: How about an electronic cutout valve before the muffler????
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
Old 04-01-2019, 02:45 AM   #2
steve99
No wont change loudness, its a resonator it jist removes a band of resonant frequencys. Its not restrictive either.
The legamax muffler is very efficient like stock. You would need to chsnge the muffler section.
You other option may be to go to a high flow cat frontpipe that will increase loudness
Old 04-01-2019, 02:50 AM   #3
Raven86Project
Thank you for the response! I already have a dual resonated front pipe, so I guess changing the muffler is the only option left (besides getting a brand new exhaust).
IG: raven86project
Build Thread HERE
Old 05-23-2019, 06:01 PM   #4
Raven86Project
IG: raven86project
Build Thread HERE
Old 05-23-2019, 06:15 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I don't get it. You have to bypass the muffler or remove the muffler packing.
Are you going to cut the mid pipe, add a Y/Tee, then attach+wire a valve and add a track pipe? Otherwise its going to be a cluster trying cut and weld to make parallel piping to bypass the packing.
You could ask an exhaust shop to mod the packing, replace the muffler with another, or just cut the muffler off, but then you'd essentially be irreversibly modding your exhaust (which would tank the resell value). You could do the same as cutting the muffler off for cheap with an actual axleback muffler delete (e.g. Berk).
Unless you're willing to go through all that trouble, might be better off from a cost and convenience standpoint to sell the exhaust and get a different one.
EndlessAzure is offline   Reply With Quote
Old 05-23-2019, 07:21 PM   #6
Raven86Project
Thanks for the response man! Yes, thinking of adding the Y/Tee in the middle pipe. I don't really care about butchering the exhaust, just want to switch from quiet to louder whenever I want.
IG: raven86project
Build Thread HERE
Old 05-23-2019, 09:02 PM   #7
humfrz
Well, that cut-out would increase the sound for sure - if you don't have a problem dumping the exhaust gasses out right under the car.
In this neck of the woods, if you drove a car with a cut-out on the road, THAT alone could get one a ticket. Plus if the LEO smelled exhaust coming out from your car, THAT would get one another ticket.
Your experience may vary -
humfrz
Old 05-24-2019, 02:04 AM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Sell the HKS legamax exhaust and put a 3" catback on instead.
Originally Posted by humfrz
I'm old and lazy
TRD exhaust resonator delete tylerdone86 Engine, Exhaust, Transmission 7 09-02-2016 11:06 PM
Resonator delete on a invidia n1? Shehadeh Engine, Exhaust, Transmission 4 08-04-2016 12:24 PM
header + resonator delete ? Who8myrice Engine, Exhaust, Transmission 3 12-24-2015 02:26 PM
TRD exhaust resonator delete? pcporo Engine, Exhaust, Transmission 19 03-15-2014 10:48 AM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 09:14 PM
