Old 08-03-2016, 12:56 PM   #1
Shehadeh
Resonator delete on a invidia n1?
Hey guys quick question for anyone running a invidia n1. Has anyone done a resonator delete on their n1 with a Tomei uel header? I'm curious to see how it sounds with the header but I don't want any rasp..
Shehadeh is offline   Reply With Quote
Old 08-03-2016, 01:57 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
don't want any rasp
Wat? ...
Old 08-03-2016, 02:24 PM   #3
tyler_win_photo
tyler_win_photo's Avatar
You will likely get rasp
tyler_win_photo is offline   Reply With Quote
Old 08-03-2016, 02:39 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
If you don't want rasp, keep the resonator. It's primary function is to reduce rasp, the mufflers primary function is to reduce volume. (Both have a secondary function of tuning the exhaust flow and sound.)
^(that is way boiled down, but if you think of the two components that way, you should understand that removing the resonator will give you rasp.)
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-04-2016, 12:24 PM   #5
kch
Senior Misanthrope
kch's Avatar
it will be raspy as hell. don't do it.
TRD catback resonator delete golemslord Engine, Exhaust, Transmission 3 07-10-2016 05:12 AM
header + resonator delete ? Who8myrice Engine, Exhaust, Transmission 3 12-24-2015 02:26 PM
Intake resonator delete. mid_life_crisis Engine, Exhaust, Transmission 2 09-12-2013 09:14 PM
invidia front pipe resonated or no resonator? bdanisi Engine, Exhaust, Transmission 1 08-20-2013 01:24 AM
Glasspack or Resonator Delete or ? Yruyur Engine, Exhaust, Transmission 6 02-02-2013 01:13 AM
