Old 03-15-2019, 09:47 AM   #1
Somerandom18
Drives: 2017 manual BRZ
Ohlins R&T v2 spring specs
Looking to get these coils but the springs are a bit too soft at 4k/3k. So I plan on swapping the springs to swift. Anyone know the length and ID of the springs front and rear?
Thanks
Sent from my Pixel 2 XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 03-15-2019, 01:23 PM   #2
Decep
Drives: 2013 FR-S Series 10
isnt this defeating the purpose of coilovers- perfectly matched spring/damper combo? Can you spec different rates from ohlins themselves? do you have to revalve the dampers too for the stiffer springs?
Old 03-15-2019, 03:38 PM   #3
Racecomp Engineering
We've done a couple custom sets of the "new" Ohlins. The price adds up if you switch to Swift springs, but we can set you up if you're interested.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Somerandom18 (03-15-2019)
Old 03-15-2019, 03:47 PM   #4
Somerandom18
- Andrew
I'll definitely shoot you guys an email thank you!
The Following User Says Thank You to Somerandom18 For This Useful Post:
Racecomp Engineering (03-15-2019)
Old 03-15-2019, 06:04 PM   #5
strat61caster
strat61caster's Avatar
48020-07 230mm 65mm 40 N/mm // 229 lbs/in // 4 kg/mm
48020-03 230mm 65mm 30 N/mm // 172 lbs/in // 3 kg/mm
Looked up the spring part number in Ohlins info online:
https://www.ohlins.com/product/road-...2012-2016-zc6/
https://world.ohlins.com/app/uploads...Subaru_BRZ.pdf
And someone helpfully posted the list of springs and specs on a BMW forum, which this forum might block the URL of, can't remember...
https://f80.bimmerpost.com/forums/sh....php?t=1323389
So 2.56" diameter (65mm), 9.06" (230mm) long
Eibach and HyperCo are cheaper than Swift ($60-$70 each instead of $80-$90 for Swift) and are regarded as the highest quality springs you can buy as a consumer, but their metric diameters are less comprehensive than Swift iirc.
@Decep one of the advantages to adjustable damping is being able to adapt the damper to a different spring rate without needing a revalve, you can usually swap springs +/-50lbs/in without noticing a big change to ride quality even without adjusting the dampers. Different designs have different ranges and different people look for different things, I think there's a couple posts on this forum about swapping springs on the Ohlins and what rates they went with.
ineedyourdiddly
Old 03-16-2019, 04:44 AM   #6
JIM THEO
Drives: BRZ 2018
Eibach is the manufacturer of Ohlins springs so a better choice from Swift, last SUS MP21 was with 4K springs all around while now Ohlins sells the same exactly suspension with 5K springs (according to their technician shocks have the same valving).
By the way I sell an MP21 with 4K springs all around, bought a month ago with less than 500 miles on it, if you are interested pm me, reason I sell it is that I need rear suspension with more travel for our uneven roads
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Somerandom18 (03-17-2019)
Old 03-17-2019, 07:07 PM   #7
Semiihcircle
Drives: 17 BRZ
So I Just pulled the trigger and ordered some ohlins, from ohlins usa. Originally i was going to have them revalved on the the spot for 6k all around. since im going to STX with coils, and 4/3k is too soft... It appears that they just updated the kit for our cars, and now includes 5k springs all around... but still nno tophat
But now im debating if i should have them revalve and with 6k springs and what tophats to go get
Semiihcircle is offline   Reply With Quote
The Following User Says Thank You to Semiihcircle For This Useful Post:
Old 03-18-2019, 09:16 AM   #8
RayRay88
Drives: 2017 86 860 Special Edition
Where did you read about the 5K all around release? I can't seem to keep Ohlins suspension straight for this car. By far the most confusing line up ever, it doesn't help that they change spring rates without changing the product code so a search of SUSMP21 provides coil overs with multiple spring rates and top hats/no top hats combinations.
RayRay88 is offline   Reply With Quote
Old 03-18-2019, 09:18 AM   #9
Semiihcircle
Drives: 17 BRZ
You gotta call them, they just updated it...
Sent from my SM-G973U1 using Tapatalk
RayRay88 (03-18-2019)
Old 03-18-2019, 11:22 AM   #10
strat61caster
imho drive them as is, change spring rates, test, tune, test again, then get a revalve after a season or two. Many people get shocks rebuilt every 1-4 years of competition depending on what level they compete at so get some experience with them before spending money changing them and knock out your first rebuild at the same time.
Developing an autox car is hard when you don't have someone to copy.
ineedyourdiddly
Somerandom18 (03-19-2019)
Old 03-20-2019, 08:02 AM   #11
Semiihcircle
Drives: 17 BRZ
Yeah thats the route im going to go, no need to spend extra, like you said if i dont have a baseline to compare it to
strat61caster (03-20-2019)
My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! kkman User/Vendor/Sponsor Reviews, Feedback, Comments 18 03-31-2016 10:59 AM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Spring bind - Raceseng CasCam & Ohlins RT 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-14-2015 02:56 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
