Old 03-11-2019, 03:25 AM   #1
Victorscp
Drives: 2018 BRZ premium
Changing rear turn signal color
Howdy gents was wondering if it's possible to change the Amber tail lights on a my17 BRZ. I want to change it to red instead of the Amber ones
Victorscp is offline   Reply With Quote
Old 03-11-2019, 07:50 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Of course. Just change the bulb. You may want to check to see if it's legal in your state.
BigTuna is offline   Reply With Quote
Old 03-11-2019, 02:26 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
The easiest way would be a film over the lights, or it's opening up and replacing LEDs which is not simple. Why red over amber?
He's MY17, they're LEDs
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Victorscp (03-13-2019)
Old 03-11-2019, 03:25 PM   #4
BigTuna
BigTuna's Avatar
Old 03-11-2019, 11:50 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
Not terrible though. A little chipquik and a hot air rework station makes the job go decently. Anyone that's done smd reflow work can accomplish it, the reflow technique is well documented. I believe they're using luxeon rebels for the rear signaling, which are straight forward enough to locate from a number of the typical electronic supply sources.
But i wouldn't recommend it as a first foray into smd soldering, as all the solder pads are underneath the chips, so reflow techniques are required, and reflow paste solder goes bad faster than most hobbyists can use it!
Old 03-13-2019, 01:41 PM   #6
Victorscp
Why red over amber?
uniformity basically
Old 03-17-2019, 07:47 PM   #7
teabubblez
Drives: BRZ 2018
You would have to essentially bake the tail lights like how you would with head lights, replace the LED with red ones that have the same draw as the existing ones (testing required) then resolder them on and finally reseal them
The safest way if you're not electrical savvy is to just buy a set of VLANDS and mod those.
teabubblez is offline   Reply With Quote
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play KI_ZN6 Exterior Parts - Lighting 685 02-18-2016 11:03 PM
Smoked & Painted Rear Tails with LED Turn Signal Bulbs Included! Cross Exterior Parts (Aero, Lighting, Etc.) 6 06-22-2014 01:51 AM
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Switchback Turn Signal Dual Color JohnAyySays Exterior Parts (Aero, Lighting, Etc.) 6 06-24-2013 04:21 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
