Old 03-11-2019, 12:26 AM   #1
levicook123
Drives: Subaru BRZ Limited
What size tires should I get for my new wheels?
Hey guys, I'm just about to order some 17×9 +35 offset wheels for my stock body BRZ and was looking into tires, what size tires should I get for the new rims? Mostly what profile should i get? I want the height of the sidewall to be more or less the same, but don't really understand what profile is other than it has something to do with that, thanks!
Sent from my SM-G965W using Tapatalk
levicook123 is offline   Reply With Quote
Old 03-11-2019, 12:36 AM   #2
Impureclient
Drives: 2015 FR-S
245/40 is the same height. 255/40 is still fine to fit also but will be slightly taller. You can go into the wheel/tire subforum to see what that will look like on other cars and even better use this: https://www.ft86motorsports.com/wheelitfit/
At stock height, it will really be poking out there with that offset wheel you are ordering. If going with coils or springs you'll be fine though. Springs will need camber bolts to get it looking right in front though.
Impureclient is offline   Reply With Quote
Old 03-11-2019, 12:50 AM   #3
levicook123
Oh yeah damn, thanks for the tip i had no idea that tool was a thing, i guess the wheel hunt continues
Old 03-11-2019, 01:39 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
Yeah, wheels are confusing after you consider the wheel dimensions are in inches, tire width is millimeters, the wheel offset is generally in millimeters measured off a phantom centerline, and then the tire sidewall is a percentage of the overall width...
It's like mfg's have gone out of their way to make it difficult.
I've used www.willtheyfit.com to check fitment as well as the link impure posted
PRICE DROP: FS: Winter/snow wheels and tires (Michelin X-ICE XI3 size 215/45/17) bd999 Wheels and Tires 8 11-02-2017 09:36 AM
tires size - 225/50/18 AE86_Mikko Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-27-2013 09:44 AM
Square Size Tires and Stagered Wheels BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-23-2012 07:44 AM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
What size tires should I get for 19s? mrha Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 12:23 AM
