Enthusiast
Drives: 2013 Scion FR-S (37J)
Square Size Tires and Stagered Wheels
I am curious if there is anything wrong with doing the same sized tires on say a 8.5/9.5 staggered set up. On my G35C I hated not being able to truly rotate the tires and I can have them pulled off to rotate if they are the same. I searched but couldn't find anything that helped. Thanks!
Drives: Attitude
Handling will change; you will add understeer by staggering the rear...among other things, but that's where we should start.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | BigJyoungblood (10-22-2012) |
Señor Member
Drives: white BRZ 6MT
I'm curious too. @OrbitalEllipses are you sure about understeer? He's running the same tire all around, so the rear is going to stretch vs the front.
Just want clarification
You'll change how the tire reacts under load by having one stretched more than the other. With a mild stretch it'll react more immediately, but also won't be as forgiving. Similar effect to having a stiffer sidewall.
| FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) | kanundrum | Wheels and Tires | 19 | 10-11-2013 09:26 AM |
| Anyone running 225/45/17 tires? How do you like that size so far? | Chimpo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-01-2012 02:24 PM |
| Think all tires of the same size ARE the same size? | Draco-REX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-26-2012 08:41 PM |
| What size tires should I get for 19s? | mrha | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-09-2012 12:23 AM |
| What size wheels do you plan on running? | poormans_LFA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 51 | 04-28-2012 05:30 PM |
