Old 03-06-2019, 11:39 AM   #1
fatoni
Track numbers
Anybody step up from painters tape but not want to spend a ton on some magnetic numbers have cheap solutions?
Drive upgrades. Don't buy them.
Old 03-06-2019, 11:55 AM   #2
Vesartis
Vesartis's Avatar
Drives: 2016 Subaru BRZ Series.HyperBlue
The organizer I run with requires magnetic or vinyl numbers. I also didn't want to spend a bunch of money, so I found these:
https://www.homedepot.com/p/E-O-Magn...C815/100345609
They are magnetic covers designed to cover vents. I traced out a design and filled it in with Sharpie. It looks fine from far away, but not great up close, but it hasn't faded yet. You could try putting some sort of vinyl or nice tape on top of the magnet, which could look pretty clean too.
I haven't had one fall off yet. (have only got up to about 100 mph on track) I always make sure they are applied to a clean surface, and that they are stored flat so the corners don't pick up.
Vesartis is offline   Reply With Quote
Old 03-06-2019, 12:02 PM   #3
fatoni
100% what I was looking to do. What organizer do you run with?
The Following User Says Thank You to fatoni For This Useful Post:
Vesartis (03-06-2019)
Old 03-06-2019, 12:07 PM   #4
Vesartis
Vesartis's Avatar
I usually run with Extreme Speed Track Events. Not always the most organized, but prices are low, which means I can do more events. They force people to buy numbers if you don't have your own, which is why I found this solution.
Old 03-06-2019, 12:09 PM   #5
fatoni
Had the suspicion. I'll be going to cvr this weekend with them. Haven't been to the track in years but finally ready to go back and have a half dozen prepaid days with them that expire this year. Let me know if you're going!
The Following 2 Users Say Thank You to fatoni For This Useful Post:
CSG Mike (03-06-2019), strat61caster (03-06-2019)
Old 03-06-2019, 12:16 PM   #6
Vesartis
Vesartis's Avatar
Cool, I will be going on Saturday. My first time at Chuckwalla, and the weather looks good, so should be a fun day. See you there!
Old 03-06-2019, 01:26 PM   #7
D-rek07
Just wanna make sure you know of trackdecals.com. $40-$50 for two, depending on the size. Expensive for a magnet, but will look professional and probably last for years.
D-rek07 is offline   Reply With Quote
The Following 2 Users Say Thank You to D-rek07 For This Useful Post:
fatoni (03-06-2019), Pat (03-06-2019)
Old 03-06-2019, 02:09 PM   #8
strat61caster
strat61caster's Avatar
You can also cut out the magnet sheets for numbers so you can swap them around for different groups requiring different numbers, co-drivers, mood, blowing sound and getting a second chance, etc.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
fatoni (03-06-2019), treedodger (03-06-2019), Vesartis (03-06-2019)
Old 03-06-2019, 02:29 PM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
DIY: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Custom made: https://www.autocrossdigits.com/
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
fatoni (03-06-2019)
Old 03-06-2019, 03:35 PM   #10
ka-t_240
I just use vinyl now. I have lost magnets during autox and had them stolen at the track before.
on warm days the magnets were fine, on cold days they would get stiff leading them not wanting to curve/stick to the body.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
fatoni (03-12-2019)
Old 03-06-2019, 03:39 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
These guys are a sponsor of Rocky Mountain 86CUP, too. Check out our website for a discount. Rockymountain86.com
The Following User Says Thank You to Pat For This Useful Post:
JoeC (03-06-2019)
Old 03-06-2019, 04:25 PM   #12
Yanbags
Yanbags's Avatar
Drives: '17 Camaro SS 1LE
I have a set from them as well. Haven't had a single issue or any surprises up to 145MPH
Yanbags is offline   Reply With Quote
Old 03-06-2019, 05:14 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeah, I've spoken with Clay, the owner about this. I've seen a lot of magnets fly off at track speeds, get run over, and be destroyed. The magnets he uses are of greater adhesion than most others. Originally I was going to cover the leading edge with clear tape, but after talking with him, I just don't think it'll be necessary.
Old 03-08-2019, 11:33 AM   #14
Yanbags
Yanbags's Avatar
Oh interesting, I didn't know that bit. Good info, thanks for sharing!
I just always make sure that there are no rocks/dust by cleaning up both the magnet and car paint surface before applying so you get the best possible adhesion.
SBD Turbo numbers? Flat_4_Life Forced Induction 11 03-03-2016 11:38 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Plasti-dip Numbers kurbkilla Cosmetic Modification (Interior/Exterior/Lighting) 1 12-05-2013 07:34 PM
Production numbers smiley6570 Scion FR-S / Toyota 86 GT86 General Forum 5 06-09-2012 08:50 AM
Brz Production Numbers WRB Bandit BRZ First-Gen (2012+) — General Topics 29 03-07-2012 09:53 PM
