Drives: 2017 Toyota 860 Specital Edition
No acceleration past 3000rpm Manual mode
Hello All. New here and just purchased a 2017 toyota 860 special edition about 3 weeks ago. It is an automatic. In normal automatic mode the car drives fine no issues. When I put the car in manual mode it is normal through 3rd gear but when I get to 4th gear and above the engine will not get up above 3000rpms. The car will get up to about 80mph and thats it. Doesnt matter if I floor it the RPMs just sit around 3000 and I can't go any faster. This is with the car warmed up and I have made no alterations to the car. Any Ideas? I'm taking her to the dealer on Monday but I have a feeling they may not be much help as I have no Warning lights on of any kind.
Thanks! |
Benz Tech
Drives: 2017 BRZ Premium
Why would they not be much help? There is a problem with your fairly new car. The dealer is exactly who needs to look at it.
Drives: 2013 brz limited / galaxy blue
Were the rev limits adjusted ?
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
^ not sure where you think a stock twin could adjust the rev limiter..
OP just take it into the dealer as it sounds like it is in limp mode... |
LMGTFY
Drives: 13 FRS, 91 Miata
Rev Limiter ≠ Shift light.
#7 | |
![]() You got the Special Edition also known as the Limited Edition. The top speed is limited because there aren't any speed limits in Utah over 80 mph. Besides, with the rpm below 3,000 you save gasoline and since your car is in the "torque dip", you won't be tempted to race mustangs. ![]() Seriously, take it back to the dealer, they can fix it. Meanwhile, I suggest you just drive in automatic mode. humfrz |
Reformed
Thanks for the responses and the help. As I said I am taking it to the dealer, the reason i asked is because the dealership responded with: "are you sure manual mode is supposed to work in the cold?" I responded that considering its been cold here since I got the car and when I first got it worked fine I would say yes. If the dealer is this ignorant about my car I'm a little worried about their ability to properly diagnosis and fix my car..... I thought maybe someone on here had possibly had a similar problem and it if it was an easy fix I could do it myself.
#10 |
Drives: 2017 BRZ
It's a "Toyota." The dealership doesn't know anything about the car.
#11 |
If a dealer every states somthing that stupid to you again, remind them they are the dealer and they are suppose to have all the answers! They may not know the answer however they have the ability to get it.
I would have had a hay day with that one! FYI 90% of what the salesman tells you is BS. Make sure you are taking with the service department, the BS percentage will go down bye 1 to 2 percent. |
#12 | |
Reformed
the one test I would recommend you try is while you are cruising going 80 in "D", move the lever to "M" and keep downshifting until the car beeps at you. Is the car properly downshifting and rev matching with each lower gear? Admittedly all the other cases where I've read a twin with an automatic transmission refusing to rev happened in both D and M, not exclusively in one drive mode.. Video wouldn't hurt either. |
#13 | |
As mentioned, you may consider taking your car into a different dealer (if feasible). If you have to take your car to that dealer, I would suggest that you ask for the service manager and relate what you were told. humfrz |
#14 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
860, let's try to at least get a warning light to come on.
Drive the car from cold until it warms up and make sure to reproduce the problem, keep it pegged against its 3000 "limit" for a while. During this drive, use both surface streets and highways. Park it, then one it's cooled down do it all again. What we want to do is have two back to back drive cycles with the problem present. Some faults need to be confirmed by the computer in two consecutive cycles before turning on a warning light. Your issue has probably logged as a pending code already, but having a light on in the dash is more ammo at the dealer. |
| Question about A/T using it in Manual mode | Oburn | Engine, Exhaust, Transmission | 46 | 07-07-2022 05:40 PM |
| AT manual mode | Brink | Engine, Exhaust, Transmission | 9 | 06-13-2018 06:05 PM |
| Manual mode issue. Please help | jsonx9000 | Engine, Exhaust, Transmission | 3 | 06-01-2018 12:28 AM |
| Automatic Acceleration in Manual vs Auto modes | kavanagh | Engine, Exhaust, Transmission | 41 | 08-04-2014 09:19 AM |
| More MPG in manual mode (AT) | aceangel | BRZ First-Gen (2012+) — General Topics | 11 | 03-27-2013 01:12 PM |
