Drives: Scion Fr-s
Manual mode issue. Please help
Hello everyone. I hope anyone can help me. I have a 2013 FRS automatic. Started about a month ago. When on Manual mode. It doesn't shift most of the time. It only happens on the main shifter. It will work if you shift a few times. The paddle shifter works just fine. Thanks in advance
#2 | |
Drives: FRS
In manual mode the gear lever wont shift consistently but the paddle shifters do, I assume is the question, if so it could be the auto tranny ecu programming, or mechanical fault or possibly tranny fluid as sources of the problem.
| The Following User Says Thank You to RFB For This Useful Post: | humfrz (05-30-2018) |
Drives: Scion Fr-s
Thank you for responding. Now I have a reference.
If the paddle shifter initiates a shift every time without fault, but the shift lever doesn’t I suspect an electronic or sensor issue at the shift lever itself. Basically, it sounds like the transmission works fine mechanically and when shifting with the paddle shifters, so I’d start there.
| Question about A/T using it in Manual mode | Oburn | Engine, Exhaust, Transmission | 46 | 07-07-2022 05:40 PM |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 02:35 AM |
| More MPG in manual mode (AT) | aceangel | BRZ First-Gen (2012+) — General Topics | 11 | 03-27-2013 01:12 PM |
| AT Manual Mode Easter Egg? | whataboutbob | Engine, Exhaust, Transmission | 2 | 12-14-2012 11:03 AM |
| AT Manual Mode Downshifting | Reprobate | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 07-23-2012 11:40 AM |
