Drives: 2015 BRZ series.blue
Good battery for car that doesn't get much use?
Hello,
I unfortunately don't get to drive my car much anymore as I switched to a remote job with no commute. Maybe once a week for a short trip now. My battery of 4 years just died so looking for a good replacement - anything you would recommend for a car that doesn't get that much use? Only aftermarket item I have on there is front and rear dash cams, but they only run when car is running (plugged in via cig lighter). Thanks! |
The Gunshine State
Drives: '14 BRZ Limited
If possible, I recommend having the battery hooked up to a trickle charger when not in use.
Or, disconnecting the battery entirely.
![]() Current DD: M235i |
I wish I could do a trickle charger but I park in an apartment garage so no access to a plug.
Drives: '13 BRZ
Optima Yellowtop.
#5 | |
Drives: 2019 BMW ///M4
You probably want one with a longer warranty, the longest I've seen is Costco with 48 Months.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#6 | |
I unfortunately can't use one as I park in a apartment garage so no access to power outlets. |
I also vote for a Costco or Walmart with a warrantee. in addition you could try a solar cell from Harbor freight, I know it is inside but the new ones will work with florescent lights but not at full power.
Famous Potatoes
Drives: '15 ultramarine
Get a 6 or 7 year battery, and if it becomes an issue, get a battery cutoff switch kit and install next to the battery (they are not expensive) under the hood. Good theft protection too.
Probably a 30-1 hour drive a week (Non-stop) should be enough to bring the battery back to full charge. If you start and stop the car often, the battery would not get back to full charge (such as turning it off and on). Do a battery test quarterly so once the battery is determined "needs a charge", just swap the battery during the warranty period. Costco one is very lenient.
N1rve
#10 | |
#11 | |
Famous Potatoes
The key doesn't work in the door? |
#12 |
Drives: '15 BRZ RA
I don't use the car during Winter period. The best option is to disconnect the battery. Otherwise, you'll need to re-charge it every second week ..
#13 |
Drives: UK GT86
There's a lock on the driver's side and a key in the fob..... it's how you get in when the battery goes flat.
.: Stealth 86 :.
#14 |
I've had good luck with "Interstate" batteries.
humfrz |
| Really good summer tire that doesn't heat cycle out quickly | Keenercarguy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 11-17-2017 05:10 PM |
| Car doesn't start without fully charged battery. | frsq5 | Issues | Warranty | Recalls / TSB | 6 | 06-09-2017 09:59 PM |
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
| Knocking doesn't sound good :-(. | TheMarkness | Issues | Warranty | Recalls / TSB | 41 | 02-04-2015 10:38 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
