Old 02-07-2019, 03:39 PM   #1
covance
Drives: 2015 BRZ series.blue
Good battery for car that doesn't get much use?
Hello,
I unfortunately don't get to drive my car much anymore as I switched to a remote job with no commute. Maybe once a week for a short trip now.
My battery of 4 years just died so looking for a good replacement - anything you would recommend for a car that doesn't get that much use?
Only aftermarket item I have on there is front and rear dash cams, but they only run when car is running (plugged in via cig lighter).
Thanks!
covance is offline   Reply With Quote
Old 02-07-2019, 03:40 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
If possible, I recommend having the battery hooked up to a trickle charger when not in use.
Or, disconnecting the battery entirely.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-07-2019, 03:51 PM   #3
covance
I wish I could do a trickle charger but I park in an apartment garage so no access to a plug.
Old 02-07-2019, 03:57 PM   #4
tobin
tobin's Avatar
Drives: '13 BRZ
Optima Yellowtop.
tobin is offline   Reply With Quote
Old 02-07-2019, 04:05 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by covance View Post
Hello,
Thanks!
Get a battery tender, if you only drive it once a week for a short trip, you're not going to get a full charge.
You probably want one with a longer warranty, the longest I've seen is Costco with 48 Months.
N1rve
Old 02-07-2019, 04:10 PM   #6
covance
what would you say is minimum amount of driving I should do per week to avoid the need for the battery tender?
I unfortunately can't use one as I park in a apartment garage so no access to power outlets.
Old 02-07-2019, 04:29 PM   #7
ls1ac
ls1ac's Avatar
I also vote for a Costco or Walmart with a warrantee. in addition you could try a solar cell from Harbor freight, I know it is inside but the new ones will work with florescent lights but not at full power.
Old 02-07-2019, 05:12 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Get a 6 or 7 year battery, and if it becomes an issue, get a battery cutoff switch kit and install next to the battery (they are not expensive) under the hood. Good theft protection too.
Old 02-07-2019, 05:21 PM   #9
N1rve
N1rve's Avatar
Probably a 30-1 hour drive a week (Non-stop) should be enough to bring the battery back to full charge. If you start and stop the car often, the battery would not get back to full charge (such as turning it off and on). Do a battery test quarterly so once the battery is determined "needs a charge", just swap the battery during the warranty period. Costco one is very lenient.
N1rve
Old 02-08-2019, 09:19 AM   #10
covance
Battery cutoff switch would be ideal but unfortunately my car is push to start. So with the battery off the only way I can enter the car is manually opening the trunk (there are no ways to manually open the doors), then knock the backseats in, then crawl into the front of the car and open the door and hood release
Old 02-08-2019, 10:18 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The key doesn't work in the door?
Old 02-08-2019, 10:57 AM   #12
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't use the car during Winter period. The best option is to disconnect the battery. Otherwise, you'll need to re-charge it every second week ..
Old 02-08-2019, 11:28 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
There's a lock on the driver's side and a key in the fob..... it's how you get in when the battery goes flat.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-08-2019, 02:39 PM   #14
I've had good luck with "Interstate" batteries.
Really good summer tire that doesn't heat cycle out quickly Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-17-2017 05:10 PM
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 09:59 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
