Old 02-01-2019, 05:03 PM   #1
wutangbrz
Drives: 2015 dgm brz
Looking for part number of wire harness
Hello. Im tracking down an issue with my windows right now and ive tracked it down to the door jam switch wiring. The door jam switch no longer recognizes when the door opens so the window does not auto scroll to clear the seal.
Ive swapped door jam switches from passenger to driver and the issue still persists on the same side.
Does anyone happen to know the part number of that wire harness/ connector that plugs into the door jamb switch? I cannot find it in any diagrams on subaruparts.com
Thanks in advance.
wutangbrz is offline   Reply With Quote
Old 02-01-2019, 07:58 PM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Thanks in advance.
Nothing to do with the wire harness. Its posted on the forum. Look for it. You just have to hold down one of the window switches and the problem is fixed.
Dr. BRZ is offline   Reply With Quote
Old 02-02-2019, 04:50 AM   #3
wutangbrz
ive tried that numerous times to 'reset' the window. believe me its not that. the door jamb switch if pressed manually will toggle the courtesy light and drop your window up or down to clear the seal when it recognizes as the door is open or closed. whatever is controlling that part of the window is not working. im going to replace the wire harness connecting that door jambs switch to the BCU
Old 02-02-2019, 09:27 AM   #4
Grady
Grady's Avatar
It is listed here.
https://parts.subaru.com/Subaru_2015_BRZ.html
Old 02-05-2019, 02:40 AM   #5
wutangbrz
Originally Posted by Grady View Post
thanks but i still cannot find it on there.
Old 02-05-2019, 01:40 PM   #6
Grady
Grady's Avatar
Looks like it is a part of the left side wire harness assembly. Subaru does not sell the connectors individually.
Go to:
WIRING HARNESS (MAIN). REAR. (1/1)
The Following User Says Thank You to Grady For This Useful Post:
wutangbrz (02-08-2019)
Old 02-08-2019, 01:27 AM   #7
wutangbrz
Go to:
thank you ill check it out
Tweeter Wire Harness Lambo_FR-S Electronics | Audio | NAV | Infotainment 4 06-13-2018 09:08 PM
part number for OEM tail lights wiring harness? bhbnuckle Cosmetic Modification (Interior/Exterior/Lighting) 0 07-16-2017 10:06 PM
Wire Harness SergeLo01 Scion FR-S / Toyota 86 GT86 General Forum 1 07-17-2014 07:06 PM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 12:05 AM
Part Number for OEM Scion H11 Foglight Harness FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 14 07-15-2013 01:01 PM
