Old 09-06-2013, 09:41 AM   #1
Lambo_FR-S
Drives: Hot Lava 2013 Scion FR-S
Tweeter Wire Harness
Hey everyone, I'm new to car audio, so please bear with me. I'd like to replace the tweeters in my FR-S without having to cut in to any wires or anything. Since there are 4 wires that plug right into the stock tweeter with a harness, does anyone know of a harness/adapter that that could plug into instead, giving me bare wires to run to my replacement tweeters? Also, I just had time to take a quick glance, but why are there 4 wires going to the tweeter instead of 2? Is something running to the other speakers mounted in the dash as well?
Lambo_FR-S is offline   Reply With Quote
Old 09-16-2013, 09:15 AM   #2
PITTFRS
Drives: 2013 FR-S Hot Lava
there should be adapters available, just not sure where from. I bought some for my tC speakers but that was years ago.
Originally Posted by Gaiakai View Post
If you're not driving like your car runs on the blood of virgins, you're doing it wrong.
PITTFRS is offline   Reply With Quote
Old 11-04-2013, 11:02 AM   #3
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I'm interested in this too. Anyone know of one?
Prog is offline   Reply With Quote
Old 06-13-2018, 07:58 PM   #4
zypher10
zypher10's Avatar
Drives: GT86
anyone find a harness for this? im looking for one.
zypher10 is offline   Reply With Quote
Old 06-13-2018, 09:08 PM   #5
CraigVM
Drives: Car Collector
Carbon Car Systems
Carbon Car Systems used to carry some great adapters and harnesses. The bad thing is they are located overseas "from the US anyway" and their videos are dated so not certain what they still offer?
I have yet to pull things apart and map out the OEM wiring on my own car as of yet ... but .... to my understanding a full range range speaker level signal comes from the OEM head unit and run up to then back out of the dash speakers. That is why you see 4 wires at that location. The dash speakers use simple capacitors to limit frequencies to upper mid and highs getting to the driver / drivers at that location. The wires leaving the dash speakers then go back to the OEM amp located in the back of the vehicle. This is still a full range speaker level signal which the amp picks up only the lower frequencies from and "amplifies" sending to the door speakers "woofers" I think some models do not include the OEM amp so the full range speaker level signal comes from the dash speakers and directly to that door speaker.
If your simply replacing the tweeters up in the dash - be certain they also employ an attached capacitor to limit only higher frequencies get to the driver. Some tweeters are designed to be fed from separate crossover which performs this same function. Full range speaker level signal getting to the driver of a small tweeter will result in a blown tweeter very quickly.
There are a good number of people who know the audio wiring inside and out so if needed I hope one of them will chime in and correct me if I am incorrect.
[ame="https://www.youtube.com/watch?v=yUE3GdqHSkE"]https://www.youtube.com/watch?v=yUE3GdqHSkE[/ame]
CraigVM is offline   Reply With Quote
tweeters wire harness
JL C5-653 mid and tweeter sure74 Electronics | Audio | NAV | Infotainment 25 02-18-2015 06:02 PM
Aftermarket Tweeter Help FRS1010 Electronics | Audio | NAV | Infotainment 9 08-02-2013 03:27 PM
1" tweeter pcporo Electronics | Audio | NAV | Infotainment 1 03-15-2013 04:02 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
free wire harness on passenger side is for? SuperDave BRZ First-Gen (2012+) — General Topics 7 08-21-2012 01:12 PM
