Old 01-28-2019, 08:47 AM   #1
rAySiiAnN
Drives: slow
Plz help :( my car wont start after replacing ignition coil pack 😭😭😭😭😭
My car was throwing p0351 codes so i went to change the ignition coil. Afterwards i tried to start it n it started up for like 1 second n stalled out really hard lol im guessing cil 1 wont fire but idk why. i put back the old coil pack and still nothing. I tries to change the spark plugs but i got the wrong size socket, maybe touching the spark plug did something? I thought the issue was the coil pack not being bolted tight enough and fortunately i snapped the bolt might as well ask for help while i wait for my stripped bolt to be removed
rAySiiAnN is offline   Reply With Quote
Old 01-28-2019, 09:31 AM   #2
Brz_racer
Drives: Subaru BRZ
Sounds like you got bigger issues, the spark plug is a 14mm deep well btw. Did you check the main fuse at the battery to see if you blew it?
Brz_racer is offline   Reply With Quote
Old 01-28-2019, 09:33 AM   #3
celek
Resident Gear Head
celek's Avatar
what spark plugs did you put in?
Also there was a rash of bad engine harnesses related to coil pack problems in 2013-14
what year is your car?
celek is offline   Reply With Quote
Old 01-28-2019, 09:35 AM   #4
Brz_racer
Drives: Subaru BRZ
It sounds like he never actually changed it
Old 01-28-2019, 09:36 AM   #5
celek
Resident Gear Head
celek's Avatar
I see that he tried but not succeeded
Old 01-28-2019, 06:50 PM   #6
rAySiiAnN
Drives: slow
The main fuse seems to be ok. It was running fine until i took out the ignition coil
Old 01-28-2019, 06:51 PM   #7
rAySiiAnN
Drives: slow
😭😭😭unfortunately 2013
Old 01-28-2019, 09:16 PM   #8
humfrz
Welcome to our forum, there rAySiiAnN -
You do realize that each of the four spark plugs has its own coil (COP - Coil On Plug)? Now that we got that out of the way.
So, was the COP that you replaced the old one with, new and right for the car?
Did you get the spark plug out? If not, it's most likely still OK.
I get the "feeling" you need to get somebody on the ground there to help you out or take your car to a shop.
I hope you get er going.
humfrz
Old 01-28-2019, 11:14 PM   #9
steve99
Check all the ignition and efi fuses
Ie any fuse designated IGxxxx or EFIxxxx
Old 01-29-2019, 06:43 AM   #10
Brz_racer
Drives: Subaru BRZ
Just so you know, the car will run without one coil connected, dont ask me how I know this...that being said if the car wont start you most likely have a fuse issue somewhere, like was said above, check all the fuses, the ones in the cabin and under the hood, you will most likely find your issue there. When you say It wont start, does it even click when you turn the key? Also if you broke the bolt for the coil that is most likely the cause of your issue, that thing needs to be fully seated to work properly. If its even a little loose you will have problems.
Old 01-29-2019, 11:20 AM   #11
rAySiiAnN
Drives: slow
It will start up normally but 2 seconds later when the rpms lower to idle (1kish) itll stall out and shake hard af �� when i give it gas itll "run" but really poorely and whenever im not pressing the gas itll spuffer n stall at idle :/ i was also thinking the problem originated because the coil pack A wasnt on tight enough which unfortunately lead to the broken bolt �� whenever i did tighten it more it seems to stall out less lol for now ive given up and had it towed to a shop i didnt check the ignition and efi fuses before they towed it but hopefully if it is just a fuse thanks for all the help everyone! Hoprfully itll be running again ��
Old 01-29-2019, 12:12 PM   #12
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
How has nobody suggested checking the grounding bolt on the DI ECU yet? That bolt is typically removed with the others that secure the DI ECU to the passenger's side fuel rail to gain access to the passenger's side coils and plugs. If you forget to reinstall the bottom bolt, which grounds the DI ECU to the block via a horizontal bracket, the engine won't run. Even if it's not tightened enough, it will cause issues and the engine may run terribly.
Old 01-29-2019, 01:43 PM   #13
humfrz
humfrz
Old 01-29-2019, 06:20 PM   #14
rAySiiAnN
Drives: slow
Oh my god....i feel so stupid, i had my car towed to a shop for no reason -_- . All the bolts were still off the ecu when i tried to start the car. Im gonna go to the shop tmr and ask to have that done im betting thats the culprit :/ thank you oh wise one ��
Any tips for replacing ignition coil B (driver front) hpde_addict Engine, Exhaust, Transmission 6 10-27-2017 04:23 PM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
None of my friends drive an 86 I need new friends😭 DVNARC Scion FR-S / Toyota 86 GT86 General Forum 41 09-21-2015 07:37 AM
ignition coil pack #2 and #3, dealer won't cover vestal52 Issues | Warranty | Recalls / TSB 28 10-16-2014 11:24 PM
Ignition Coil C replacing - need assistance Synack Issues | Warranty | Recalls / TSB 8 09-09-2014 03:35 PM
