Old 03-25-2013, 10:49 PM   #1
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
T1R Full Exhaust re-dyno x DRIFT OFFICE TUNE !!!!
Hi Guys
Sadly, the original dyno facility has been closed down and we have to source another dyno facility. this time all dyno runs will be performed with Dynapak hub Dynometer.
We started fresh again so we put the car back to stock and to do the base run. We made 151.3whp (stock) 131WTQ .
- The red dotted line is stock (151.3WHP) / Pink line is with T1R 70R cat-back (159.3WHP)
The cat-back exhaust gained 8WHP / 2WTQ at peak . From 3500-4500rpm it gained 2~4.1WHP 1~2.5WTQ. At 5000-6500rpm it gained 5~8WHP /5~8WTQ. The factory torque dip got narrowed.
- red dotted line is STOCK (151.3WHP)/ Blue line is with T1R 70R exhaust (159.3WHP) / Yellow line exhaust with front pipe (162.6WHP)
With the addtion of the Front pipe, it showed 3WHP at peak. At 4000rpm it gained 2WHP & 4WTQ. From 5000-6500rpm , it gained 1~2WHP and 2~6WTQ. The Stock torque dip got narrowed more.
- Red dotted line stock (151.3WHP)/ Blue line 70R exhaust + Front pipe / Pink line 70R exhaust + FP+ Over pipe (162.8WHP).
The T1R Over pipe did help to improve the mid-range toque but not much in power. It gained about 1~2WTQ from 4000-6200rpm and about 0.5WHP at peak. As well, the torque dip got narrowed.
- Red dotted line stock (151.3WHP) vs Pink T1R Prototype Header, over pipe, front pipe and cat-back exhaust (165.1WHP)
From the test, the header gained another 2.3WHP at peak and 2~4WHP / 3~5WTQ at 3000-4000rpm. However, the air fuel ratio was leaning out so if we can rich up the engine a bit, we should see another 3-5WHP gain.
Here's the A/F :
- The red line is the T1R Header + Full exhaust and the blue line is T1R header + Full exhaust + Visconti TUNE
The tune didn't work out with the T1R exhaust setup so it ended up power loss. So We talked to BOB @ Drift Office and he said he can fix the tune for us. Then we headed down south !
At Bob's facility, he does not have the same dyno so we have to do a baseline with his DYNOJET. The baseline was 168whp, comparing to our last result with DYNAPAK, it showed about 3whp more so now we all know there's a 3whp difference
Bob @ Drift Office did an excellent job. The T1R is a very powerful setup and with the tune it made 20whp at peak vs baseline and from stock is +35whp and +14WTQ TOTAL.
We will be hacking up the header again and make it with bigger primaries and secondaries, we will be aiming over 190whp !
Stay tuned !
Ben @ AJR
AJ PwR is offline   Reply With Quote
Old 03-25-2013, 10:52 PM   #2
AJ PwR
AJ PwR's Avatar
Save for Product pictures ~!
Old 03-25-2013, 10:54 PM   #3
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
All with stock intake?
shu5892001 is offline   Reply With Quote
Old 03-25-2013, 11:38 PM   #4
AJ PwR
AJ PwR's Avatar
Yes it has stock intake !
Old 03-25-2013, 11:44 PM   #5
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
I'll confirm that since that's what I insisted on. Also note the alleviation of the dreaded torque dip; while it's not gone, it's certainly less pronounced and this is just a start since they're still developing the product.
Looking forward to more goodness from AJR and T1R!
Regards!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 03-26-2013, 08:47 AM   #6
buditjoenawan
Drives: Very very slowly
@Drift-Office, what's happening during the 2 dips in the midrange?
-budi
buditjoenawan is offline   Reply With Quote
Old 03-26-2013, 09:52 AM   #7
shu5892001
Ontario's FT86
So this is a catless setup?
Old 03-26-2013, 10:53 AM   #8
mad_sb
Drives: 2013 Asphalt FR-S
-budi
Those look like sample drop outs... for some reason the software hickups every now and then causing it to miss a sample or two.. this happened at the last dynojet i used too.
Nice work guys, I appreciate the thorough testing :happy0180:
Old 03-26-2013, 05:36 PM   #9
AJ PwR
AJ PwR's Avatar
Yes
Here's the dyno plot that we dyno at the beginning. This flash is from Visconti.
- The red solid line is with T1R Header + Full exhaust and the blue line is T1R Header + exhaust + Visconti Tune.
The Visconti flash didn't work with the setup. We have power loss almost everywhere so we ended up having Bob (Drift Office) to help us to fix it and once again, Bob did an excellent job
Old 03-27-2013, 08:56 AM   #10
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Did you get to do any runs with the Ti version?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-27-2013, 02:15 PM   #11
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Nice!! Is there a club member deal or group buy for T1R 70R exhaust? By far this is my fave exhaust amongst all!! Keep up the excellent work!
RehabJeff86 is offline   Reply With Quote
Old 03-27-2013, 05:02 PM   #12
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I am looking for the highest Hp setup and I am looking at it possibly? I'd really like to hit 200 whp with 93 and bold-ons.
TouchMyHonda is offline   Reply With Quote
Old 03-27-2013, 05:54 PM   #13
ajrcow
ajrcow's Avatar
Drives: Scion FRS
By judging the numbers and mods that's on his car, I think it is possible to get close to 200whp. I am not sure if an intake will help with this setup and if does, by adding it and some pulleys should hit it !
ajrcow is offline   Reply With Quote
Old 03-27-2013, 09:56 PM   #14
AJ PwR
AJ PwR's Avatar
The Titanium and Stainless perform the same. The only difference will be the weight.
I am working on it
This is what I am thinking. IMO, the car is quicker than s2k with light mods so a little more acceleration and top end, it will be very competitive
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Drift-Office : EcuTek Calibrations Drift-Office Engine, Exhaust, Bolt-Ons 24 05-21-2013 04:33 AM
Drift-Office Stage 1, 92 Oct tune BRZranger Engine, Exhaust, Transmission 15 01-07-2013 09:40 PM
AVO Inlet Kit tested at Drift Office AVOturboworld Engine, Exhaust, Transmission 26 10-02-2012 04:21 PM
Drift-Office : BRZ vs FRS Dyno Day ~ Mini Meet 6/30/12 Drift-Office Northwest 42 07-10-2012 04:03 AM
