pessimistic skeptic
which springs for bilstein b6
Just ordered the Bilstein B6 shocks//struts and I am looking for a set of springs now. I want nothing more than maximum 1" drop and just a bit stiffer than stock FR-S suspension. I was looking at Eibach Pro, Tein H Tech, RCE Yellows. Are TRD springs better?
Drives: 2013 FR-S Series 10
rce yellows hands down. IMO they're a bit much for stock dampers but i think the b6s would handle them well.
Drives: '14
Someone correct me if I'm wrong but aren't the Bilstein B6's designed for stock height springs while the B8's were designed for lowering springs?
pessimistic skeptic
Drives: Legacy GT
It's my impression the B8 does not offer any additional bump travel over the B6 in this application.
I think all you get is shorter travel which might keep some springs from unseating at full droop. But any spring that would do that on a b6 is probably really crappy and too low. |
Drives: 2015 BRZ
+1 for RCE Yellows these are great springs.
pessimistic skeptic
Any significant advantage of progressive springs of trd/eibach-pro?
TRD and RCE springs are also manufactured by Eibach but RCE springs are not progressive. |
#8 | |
Both kits come with shorter bump stops but you’ll only be using the rears anyways. I have had RCE (20mm drop) on my B6s and JDM STi (~10mm drop) and I can tell the struts/shocks appreciate the extra travel. |
Famous Potatoes
Drives: '15 ultramarine
TRD
#10 |
RCE Yellows are not made by Eibach. In the USA Eibach is the OEM for TRD springs. Go with RCE Yellows and rear LCAs to get rid of the camber in the rear.
2013 Series 10 FRS #553
#11 |
Country Boy 4 Life
What's wrong with a little negative camber? RCE probably only will add -1.5, which won't cause weird tire wear. It's toe that can if you do not get an alignment after install. Not that LCA are a bad Idea; just that most want them to add camber...
I LIKE TIRES! |
#12 | |
#13 | |
Country Boy 4 Life
OP, I had Prokit springs for 65,000 miles of daily driving. I really liked them. But, many times I wondered if RCE would have been a better choice for my style of driving. I know I keep suggesting it in threads, but I also wish that I had installed a bumpsteer roll center kit when I installed my springs a long time ago. (And maybe some LCA too )DD build... Springs Camber bolts Bumpsteer kit LCA
I LIKE TIRES! |
#14 | |
| Bilstein B6 + Tarmac Springs + Raceseng Cascam | Butterballz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-01-2018 12:01 AM |
| Bilstein B8|RCE Tarmac Springs|Racer-X LCA|More | H1C | Brakes, Suspension, Chassis | 3 | 02-19-2018 12:05 AM |
| Bilstein b6 + Stock springs | JMon85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 135 | 07-17-2017 11:19 AM |
| RCE Tarmac springs w/ Bilstein B8 struts | drifter-s | Brakes, Suspension, Chassis | 2 | 05-31-2017 10:50 AM |
