Old 01-18-2019, 08:30 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
which springs for bilstein b6
Just ordered the Bilstein B6 shocks//struts and I am looking for a set of springs now. I want nothing more than maximum 1" drop and just a bit stiffer than stock FR-S suspension. I was looking at Eibach Pro, Tein H Tech, RCE Yellows. Are TRD springs better?
Old 01-18-2019, 08:31 PM   #2
Decep
Drives: 2013 FR-S Series 10
rce yellows hands down. IMO they're a bit much for stock dampers but i think the b6s would handle them well.
The Following User Says Thank You to Decep For This Useful Post:
mrg666 (01-18-2019)
Old 01-18-2019, 08:35 PM   #3
kev0
Drives: '14
Someone correct me if I'm wrong but aren't the Bilstein B6's designed for stock height springs while the B8's were designed for lowering springs?
kev0 is offline   Reply With Quote
Old 01-18-2019, 08:51 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
Just like stock shocks/struts, B6 can go up to 1" lower than stock. If you want to lower more, B8 is recommended.
The Following User Says Thank You to mrg666 For This Useful Post:
kev0 (01-19-2019)
Old 01-18-2019, 09:33 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
It's my impression the B8 does not offer any additional bump travel over the B6 in this application.
I think all you get is shorter travel which might keep some springs from unseating at full droop. But any spring that would do that on a b6 is probably really crappy and too low.
jamal is offline   Reply With Quote
The Following 4 Users Say Thank You to jamal For This Useful Post:
mrg666 (01-18-2019), strat61caster (01-18-2019), Ultramaroon (01-19-2019), ZDan (01-19-2019)
Old 01-18-2019, 09:49 PM   #6
Vital
Drives: 2015 BRZ
+1 for RCE Yellows these are great springs.
The Following User Says Thank You to Vital For This Useful Post:
mrg666 (01-18-2019)
Old 01-18-2019, 10:10 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
Any significant advantage of progressive springs of trd/eibach-pro?
TRD and RCE springs are also manufactured by Eibach but RCE springs are not progressive.
Old 01-18-2019, 10:31 PM   #8
norcalpb
norcalpb's Avatar
Progressive springs will be more comfortable on bumpy roads, but will give a more unpredictable feeling when driving the car hard.
Both kits come with shorter bump stops but you’ll only be using the rears anyways.
I have had RCE (20mm drop) on my B6s and JDM STi (~10mm drop) and I can tell the struts/shocks appreciate the extra travel.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Leonardo (01-18-2019), mrg666 (01-18-2019), Ultramaroon (01-19-2019)
Old 01-18-2019, 11:49 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
TRD
mrg666 (01-19-2019)
Old 01-19-2019, 01:37 AM   #10
jflogerzi
jflogerzi's Avatar
RCE Yellows are not made by Eibach. In the USA Eibach is the OEM for TRD springs. Go with RCE Yellows and rear LCAs to get rid of the camber in the rear.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
mrg666 (01-19-2019)
Old 01-19-2019, 01:41 AM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What's wrong with a little negative camber? RCE probably only will add -1.5, which won't cause weird tire wear. It's toe that can if you do not get an alignment after install. Not that LCA are a bad Idea; just that most want them to add camber...
I LIKE TIRES!
mrg666 (01-19-2019)
Old 01-19-2019, 01:46 AM   #12
jflogerzi
jflogerzi's Avatar
Its late... long day at work and you are right. LCAs give you more
Leonardo (01-19-2019)
Old 01-19-2019, 01:59 AM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
OP, I had Prokit springs for 65,000 miles of daily driving. I really liked them. But, many times I wondered if RCE would have been a better choice for my style of driving.
I know I keep suggesting it in threads, but I also wish that I had installed a bumpsteer roll center kit when I installed my springs a long time ago. (And maybe some LCA too)
DD build...
Springs
Camber bolts
Bumpsteer kit
LCA
I LIKE TIRES!
mrg666 (01-19-2019)
Old 01-19-2019, 02:08 AM   #14
jflogerzi
jflogerzi's Avatar
DD build...
Springs
Camber bolts
Bumpsteer kit
LCA
Well I got 3 out of 4 on mine so not so bad.
Bilstein B6 + Tarmac Springs + Raceseng Cascam Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-01-2018 01:01 AM
Bilstein B8|RCE Tarmac Springs|Racer-X LCA|More H1C Brakes, Suspension, Chassis 3 02-19-2018 01:05 AM
Bilstein b6 + Stock springs JMon85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 135 07-17-2017 12:19 PM
RCE Tarmac springs w/ Bilstein B8 struts drifter-s Brakes, Suspension, Chassis 2 05-31-2017 11:50 AM
