Old 01-14-2019, 02:15 PM   #1
F14Scott
F14Scott's Avatar
Drives:
Interesting USB bug that left my battery dead.
I wanted to charge an external Lion battery pack while I drove, so I plugged it into my '18 BRZ USB port, where it began charging immediately. When I shut down the car, however, it then reversed its flow and started trying to charge my car. This introduced current confused the car, which then did not shut down my radio or Bluetooth when I opened my door.
The next morning, the car's battery was dead. I charged it and all was well. When I don't have the Lion battery plugged in, the car shuts down and acts normally.
So, the moral of the story is that current applied to the USB port at engine shutdown might inadvertently command some accessories to remain powered up, draining the car's battery, eventually.
Cheers!
Sent from my SM-G965U using Tapatalk
F14Scott is offline   Reply With Quote
Old 01-14-2019, 02:28 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Unless there is a good reason to allow DC current flow back into the vehicle from the USB port it would seem reasonable that a diode might be a good addition to the circuit. It may not be that simple, however, depending upon how DC and data are combined in the physical circuitry.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
F14Scott (01-14-2019)
Diagnosing dead battery amaciose Electronics | Audio | NAV | Infotainment 1 11-06-2016 01:55 PM
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 09:58 AM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 01:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
