Old 11-06-2016, 01:45 PM   #1
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Diagnosing dead battery
Looking for some other opinions on what might be killing my battery.
Last Friday night I installed the TapTurn flasher relay and the DiodeDynamics Tail-as-Turn module with replacement backup LEDs in the turn signal position.
The following day I tried to start the car and found I had a completely dead battery. I couldn't get the windows or trunk to function without a jump start.
Would either of the two mods above cause a parasitic drain on the battery or is the dead battery just a coincidence? The tail-as-turn module is the new version with the built-in resistor. Could there be a short across this resistor that is draining the battery?
Thanks!
amaciose is offline   Reply With Quote
Old 11-06-2016, 01:55 PM   #2
amaciose
amaciose's Avatar
Maybe this should be moved to Cosmetic Modification... sorry mods.
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 04:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 09:58 AM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 01:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 04:06 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 01:29 PM
