Old 01-09-2019, 05:08 PM   #1
incutebus
Drives: Boosted
Still worth it on going catless header with stock cbe in cali?
Was wondering if the volume increase is noticeable with just a catless header just enough to give a cop a hardon.
incutebus is offline   Reply With Quote
Old 01-09-2019, 05:11 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm sure you will be fine as long as you don't book it near one.
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
eastendraceshop (01-09-2019), incutebus (01-09-2019), Joveen (01-10-2019)
Old 01-09-2019, 05:27 PM   #3
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
+1 to the above.
eastendraceshop is offline   Reply With Quote
Old 01-09-2019, 05:45 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
Noticeably louder yes, especially cold starts. Stupid loud at cruising speeds and normal acceleration, not at all.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
mgarcia707 (01-15-2019)
Old 01-09-2019, 06:58 PM   #5
jflogerzi
jflogerzi's Avatar
You gotta pay to play. If you get a header get a tune.. without a tune like the OFT aftermarket headers are pointless
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
mgarcia707 (01-15-2019), x808drifter (01-09-2019)
Old 01-10-2019, 12:15 PM   #6
incutebus
Drives: Boosted
That's a given lol
Old 01-14-2019, 08:51 PM   #7
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Should be fairly quiet with stock muffler and catted FP.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 01-14-2019, 09:24 PM   #8
weederr33
weederr33's Avatar
Just to amend my previous post, don't you guys in California now have some strange 95 dB exhaust law? I think you'd be fine but again, you'd have to be careful.
Old 01-15-2019, 12:55 AM   #9
The same law that's been in place for 15+ years? Yes.
wparsons (01-17-2019)
Old 01-15-2019, 01:42 AM   #10
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Aftermarket header/ oem fp/ oem cbe is still very quiet. You'll be fine.
Now if you remove the OEM FP for a catless FP... you'll hear more noise but it's not that bad.
Changing the OEM FP and OEM CBE will definitely make things loud so.... keep the OEM FP in.
Decimus is offline   Reply With Quote
Old 01-15-2019, 03:05 AM   #11
mkodama
86 Challenge
Drives: 2017 BRZ
I have the Tomei equal-length headers and stock everything else. Still quieter than any aftermarket exhaust and I have zero fear of noise problems.
It’s barely louder than stock.
mkodama is offline   Reply With Quote
Old 01-15-2019, 07:50 AM   #12
weederr33
weederr33's Avatar
I'm not from there so I'm just going off of the recent hype.
Old 01-15-2019, 10:22 AM   #13
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
only thing that changed with this "new" law is they made exhaust modification a non correctable violation with a fine of up to $1,000. That's where the problem lies, and they made it where its the cops discretion with or without a decibel meter.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
weederr33 (01-15-2019)
Old 01-15-2019, 01:12 PM   #14
e_lunatic
Drives: 2015 Scion FR-S
i have a Gruppe-S UEL header with stock OP, FP, and CBE w/ an OFT tune. it's not any louder it just has a different pitch. I haven't given it a second thought. I wouldn't be any more concerned about how it sounds near a cop than a full stock exhaust. I say go for it as long as you wouldn't make yourself crazy with worry.
e_lunatic is offline   Reply With Quote
Video Request: Stock OEM Exhaust + Catless Header + Catted FP M23 Engine, Exhaust, Transmission 26 08-11-2016 06:19 PM
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
Stock header and cat back plus catless front pipe FRSBRZGT86FAN Engine, Exhaust, Transmission 0 05-31-2015 12:19 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
