Old 01-09-2019, 05:35 PM   #1
Butterballz
Drives: Black FRS
OEM Radiator Hose Expansion
Hello,
So I recently installed a Jackson Racing Dual Radiator/Oil Cooler along with the included 1.4bar radiator cap. I've been having issues with the lower radiator hose touching the bottom of the oil control valve.
Has anyone else ran into the same issue? I believe it's cause the hose is expanding but maybe I aligned the hose incorrectly. It doesn't touch when cold with at least a finger or two gap between the bottom of the control valve. After driving, it's touching. I'm not sure if it can expand that much.
Also, anyone knows if silicone hoses are more expansion resistant? I didn't want to go that route but if it prevents the hose from touching, I don't have much choice.
Thanks!
Butterballz is offline   Reply With Quote
Old 01-09-2019, 07:19 PM   #2
Grady
Grady's Avatar
Shouldn’t expand that much. Possibly installed with a twist in it?
Pictures?
Old 01-09-2019, 07:28 PM   #3
Butterballz
Drives: Black FRS
Pictures?
Only photo I have. I've tried twisting the hose from the thermostat housing to align the text on the hose but it started to deform the hose. The way it is on the photo is how the hose wants to sit without starting to collapse a bit from twisting.
Old 01-09-2019, 08:17 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
May or may not be your issue, but did you put the hose on in the same way you took it off? It’ll fit fine either way but hose will be routed slightly different depending what end you put on radiator.
Old 01-09-2019, 08:23 PM   #5
Butterballz
Drives: Black FRS
It should be the correct orientation. Matches photos I see online with the hard bend on the engine side and the side with multiple bends to the radiator. Bought new OEM hoses as well.
Old 01-09-2019, 10:10 PM   #6
Butterballz
Drives: Black FRS
Here's a picture after the car is up to temp. Gonna switch to the oem radiator cap to see if it's pressure related.
Old 01-09-2019, 10:31 PM   #7
ls1ac
ls1ac's Avatar
To have a hose expand an inch there is either broken fibers or there is a leak to the outer lining.
If it is not expanding but reorienting under pressure and heat there is a twist in the install.
Look at it when hot and running standing still of course.
Old 01-10-2019, 09:41 AM   #8
Grady
Grady's Avatar
A) re-orient the hose when cold to a larger gap.
If that does not work.
B) add chafe protection.
Old 01-10-2019, 01:25 PM   #9
Butterballz
Drives: Black FRS
Looks like it's pressure related. I swapped over to the oem radiator cap and when the engine is fully warmed up, there is clearance between the hose and oil control valve. Seems like the 1.4bar pressurizes it a bit too much where it wants to straighten the hose to the point it touches.
I'll try to see if I can reorient the hose but as far as I know, it should be oriented correctly. There doesn't seem to be any kinks or twist in them. The hose follows the path of its shape naturally.
Thanks guys!
The Following User Says Thank You to Butterballz For This Useful Post:
Ultramaroon (01-10-2019)
Perrin Radiator Hose Oburn Engine, Exhaust, Transmission 8 06-19-2014 06:13 PM
NPA: Mishimoto FR-S/BRZ Silicone Radiator Hose Kit 86_Insider Engine, Exhaust, Transmission 0 08-19-2013 10:43 PM
ZetaPerformance 6PC Radiator Hose Kit Installed Lverasky Engine, Exhaust, Transmission 9 04-19-2013 01:04 PM
Fuku Works Radiator Hose Kit Mach V Dan Engine, Exhaust, Bolt-Ons 4 09-12-2012 12:22 PM
