Old 12-31-2018, 11:32 AM   #1
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Ecutek License Question
-Car has been tuned on 93 using Ecutek (racerom upgraded) with Tuner A. Currently only have 1 map.
-Looking to use a different Tuner B in town(for various reasons) for a new flex fuel map and remain on Ecutek using same dongle etc.
1) Do I need to purchase a new Ecutek license for new tuner B to create a new map?
I attempted to find my answer here in the forums and their page but to no avail. Thanks in advance!
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 12-31-2018, 11:37 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The license is applied to your dongle, so if you're holding the dongle, they can put it into their computer and tune away
Old 12-31-2018, 12:53 PM   #3
tomm.brz
Drives: brz 2017 hksv2
You won t need to buy a new license, but I didn't understand if You have a ecutek kit at home or not. Did you remote tune your car with Tuner A?
Tuner B must do a new tune from scratch and you will communicate your 6digits dongle ID and he will send you tunes that will open on your ecutek kit
Old 12-31-2018, 01:33 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Simple answer is no, you don't need to purchase one. The ECU license is flashed to the ECU and is therefore a new one is not required once the ECU initially flashed.
The dongle is just the software license for the laptop/PC software.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-31-2018, 02:21 PM   #5
mmmcambelsoup
Thank you all, that answered my question. I have ECUTEK kit in hand, so from what I understood I have everything I need to just go to Tuner B and tune away on new map.
IG: @Lucky_FatPat
Old 01-04-2019, 05:59 AM   #6
504
504's Avatar
Drives: 2014 86 GTS
for the sake of avoiding another thread,
I have an ecutek licence and fully tuned by my tuner. Recently acquired a ecutek cable but a licence dongle of another car, can I plug this into my car just for datalogging purposes?
504 is offline   Reply With Quote
Old 01-04-2019, 07:56 AM   #7
Fred E
Drives: WRB BRZ
You shouldn't have a problem. The only limitation as far as i know would be that any tune files that you would want to flash with this other dongle would need to be keyed for that dongle ID.
Fred E is offline   Reply With Quote
Old 01-04-2019, 08:10 AM   #8
tomm.brz
Yes you can, just open a stock rom of your CalId and apply a racerom patch and start logging
Old 01-04-2019, 02:34 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
So long as the RR patch is of the same version. If it's not some of the RR parameters may not log correctly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-04-2019, 04:13 PM   #10
tomm.brz
Yes, you re right, i ve experienced errors too with a wrong rr patch, but mostly just works
Old 01-04-2019, 06:41 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's because the logging addresses can change as the different patches use different RAM locations. Some of the older patches changed so much between versions that very few of the RR parameters worked if you have the wrong patch applied and IMO the OEM parameter list on EcuTek isn't the best. It's less of an issue on the newer patches but if you happen to have an older one on the car and can't find the right patch you might find the logging is a little bit pointless.
@504 as it's your tuner that did the original flash, just get him to change the Keying on the ROM to your new dongle ID and get him to send it to you. Then you can use that, it's the easiest solution. Or ask him the ID of the RR patch if he won't send it to you.
.: Stealth 86 :.
Kodename 47 DJ:
Need ECUTek license nlowell Software Tuning 1 05-20-2017 11:38 AM
Ecutek License Help fizzymike Software Tuning 2 04-17-2017 08:25 PM
EcuTek license? mike_ekim1024 Software Tuning 11 11-10-2016 07:00 PM
FS: EcuTek license Stealth Gt86 Audio/Visual, Electronics, Infotainment, NAV 1 04-30-2014 06:13 PM
ECUTEK license question protpibe Software Tuning 2 01-19-2014 10:36 PM
