Old 12-20-2018, 04:44 PM   #1
JIM THEO
Drives: BRZ 2018
Subframe mount inserts choice
Which are the softest subframe mount inserts among Whiteline, Superpro, Powerflex, Polypro, Torque solutions etc, I want the minimum possible NVH increase.
JIM THEO is offline   Reply With Quote
Old 12-20-2018, 05:01 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What's wrong with OEM?
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Efferalgan (06-08-2025), kch (12-20-2018), Strife26 (12-20-2018)
Old 12-20-2018, 05:33 PM   #3
86MLR
86MLR's Avatar
I found I didnt get much NVH from my cheapo ($35 on sale) Hardrace inserts, and they were pretty hard.
My Hardrace diff support ($80 on sale) on the other hand has added a fair bit of NVH.
Not overly annoying (for me), but loud enough for my daughter to notice when she drives the car.
Actually, take into concideration my loud(ish) exhaust with 2017 OEM punched out header, 2.5" overpipe, and 2.5" X Force overpipe back, and my Hankook RS4's which are pretty loud.
Whilst the subframe bushings gave a good improvement, the diff mount support added greatly to the overall improvement, albeit with added NVH.
I would assume diff support mount bushing inserts (like the whiteline pn KDT925) might be better than the support brace IRT NVH.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 12-20-2018, 05:37 PM   #4
86MLR
86MLR's Avatar
OEM are fine for driving to the shops, but they fall over real quick when it comes to performance.
The saying "throwing a sausage down a hallway" comes to mind.
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
JIM THEO (12-20-2018), Leonardo (12-20-2018)
Old 12-20-2018, 05:50 PM   #5
strat61caster
strat61caster's Avatar
Whiteline inserts were a nice upgrade, no big change to nvh.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Leonardo (12-20-2018), smg1138 (02-10-2019)
Old 12-20-2018, 06:10 PM   #6
JIM THEO
Drives: BRZ 2018
Are they plastic or am I seeing wrong?
And do they induce sudden oversteer at the limit?
Old 12-20-2018, 06:21 PM   #7
JIM THEO
Drives: BRZ 2018
They are very sloppy, at hard cornering you feel the chassis floating over the subframe or at least this is my feeling from day one I drive this car, something is wrong back there!
Just wondering should I wait to install first my new Ohlins coilovers or to install them altogether?
The Following User Says Thank You to JIM THEO For This Useful Post:
Old 12-20-2018, 06:53 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks for your answers.
Question: Why were they suspect from day one? Why not some other part(s)?
Like one of these parts: Coilovers, sway bars, endlinks, ball joints & tie rod ends, LCA, trailing arms, and toe arms.
I just replaced all those parts and my steering is much tighter, but I also have WAAAY more NVH.
Eventually I want to get the Complete Front and rear Whiteline bushing kits.
I LIKE TIRES!
Old 12-20-2018, 06:59 PM   #9
86MLR
86MLR's Avatar
Yes they are a plastic (thermoplasic??), they resist cracking more than poly.
Sudden oversteer at the limit?, not from my experience, if you are having sudden oversteer at the limit??? (limit of what, tyre???/skill???), I would say thats more of a tyre and/or suspension/alignment issue.
Old 12-20-2018, 07:05 PM   #10
JIM THEO
Drives: BRZ 2018
I have this feeling from day one, not that I suspect subframe bushings are responsible for this from day one, that's why I ask if I should install first coilovers and see how it drives.
I think my description is very precise as if the car floats over the subframe and rear wheels, not directly connected with them, and is not the sway bar nor soft tires (215/40/18 PSS).
@86MLR no I haven't sudden oversteer just asking cause the car is super friendly at the limit and I want to keep this characteristic
new2subaru (12-20-2018)
Old 12-20-2018, 07:11 PM   #11
new2subaru
Weight Weenie
Drives: 15 FR-S
Yup, I felt the same thing. I installed this bushing kit and it tightened it right up.
https://www.whiteline.com.au/product...DT922&sq=22167
I would do it first so that you can appreciate the difference such a simple mod makes.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
JIM THEO (12-20-2018), steel86gt (01-22-2019)
Old 12-20-2018, 07:16 PM   #12
86MLR
86MLR's Avatar
Throw in the suspension and the inserts.
I have mca coilovers 6kg f, 4.5kg r, dampening set to about midway, mca traction mod in the rear, stock sways with subframe bush inserts and the diff mount support brace.
Car is what I would call balances, very steady and predictable.
Unlike before when the arse would wallow around and be unpredictable.
JIM THEO (12-20-2018), new2subaru (12-20-2018)
Old 12-20-2018, 07:19 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I got this feeling when I upgraded my tires. I'm going to get a thick sway bar in the rear and lower it on pro kit springs to see how much better it feels.
DarkPira7e is online now   Reply With Quote
Old 12-20-2018, 07:20 PM   #14
new2subaru
Weight Weenie
Drives: 15 FR-S
Jim,
Here's how I did my install. Hope it helps. Post 73
http://www.ft86club.com/forums/showt...t=20920&page=6
The Following User Says Thank You to new2subaru For This Useful Post:
Sold 86TOYO2k17 Transmission and Driveline 9 03-28-2020 02:00 PM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 11:24 AM
FS: SuperPro subframe inserts & LCA inner bushings xn7485 Brakes, Suspension, Chassis 1 09-13-2017 03:23 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 09:20 PM
