Old 12-18-2018, 03:42 AM   #1
Legend@wheels
nenber
bleeding
hi
is there any real advantage by doing clutch/brake bleeding with pressure?(like someone to press the brake pedal/clutch pedal)instead of just open the nipple and let it bleed itself.
Legend@wheels is offline   Reply With Quote
Old 12-18-2018, 03:52 AM   #2
swarb
Time
Old 12-18-2018, 03:57 AM   #3
Legend@wheels
nenber
as i thought.
thanks
Old 12-18-2018, 04:42 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
I tried gravity bleed and gave up after 30 minutes. Might be fine if you can leave the car sit for a while.
Old 12-18-2018, 05:29 AM   #5
86MLR
86MLR's Avatar
A getto trick is to use a large syringe matched to a vacuum line hose that fits tight on the nipple.
Connect syringehoseatron-lossen nipple-suck fluid- tighten nipple-empty syringe and go again.
I've done this a few times, never had a issue.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 12-18-2018, 05:54 AM   #6
Legend@wheels
nenber
A good one!
Old 12-18-2018, 04:33 PM   #7
gravitylover
That's pretty much how I bleed mt bike hydro brakes. Down and dirty - done.
Old 12-18-2018, 05:35 PM   #8
JIM THEO
Drives: BRZ 2018
I do the same, first I take all the brake fluid from the plastic container and refill with my preferred one and then follow your procedure.
But it needs good bleeding, 100-200kms of driving and bleeding again as to replace all the old brake fluid.
JIM THEO is offline   Reply With Quote
Old 12-19-2018, 12:10 AM   #9
highway7
Drives: FRS 2013
Wow, will have to try this next time
highway7 is offline   Reply With Quote
Old 12-19-2018, 12:48 AM   #10
Legend@wheels
nenber
I cant see the benefit by driving it and bleed it again.
Sent from my SM-G960F using Tapatalk
Old 12-19-2018, 02:15 AM   #11
JIM THEO
Drives: BRZ 2018
Have been told from Subaru mechanic that ABS valves keep some fluid inside!
Old 12-19-2018, 10:09 AM   #12
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Get a scan tool that does ABS bleed, problem solved. Cheapest one on Amazon is around $225.
Trueweltall is offline   Reply With Quote
Old 12-19-2018, 01:44 PM   #13
JIM THEO
Drives: BRZ 2018
4-5 times the cost of new good brake fluid while labor is quite cheap locally...
Old 12-20-2018, 12:20 AM   #14
Legend@wheels
nenber
you didnt say anything
exactly
brake bleeding, air in abs? Grip Ronin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-22-2018 07:34 PM
Bleeding Air through TPMS GarStar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2015 02:14 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 10:31 AM
Speed Bleeding time away developer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-31-2012 07:07 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
