Old 12-10-2018, 09:13 AM   #1
randomthoughts
Drives: 2014 White BRZ
Pulling Tranny - What bushings/ parts to upgrade
I will be pulling my transmission to install my Money Shift hydraulic release bearing. I plan on installing the Whiteline Transmission mount and the Perrin rear shifter bushing.
Is there anything else I should consider upgrading while I have the transmission out?
randomthoughts is offline   Reply With Quote
Old 12-10-2018, 04:11 PM   #2
86league
Drives: '13 BRZ Limited
I can't speak for how much they help - but I'm prepping to pull the trans from mine to do a TOB/clutch replacement. The shifter carrier on mine has a lot of play - a lot more than I would have expected. I ordered those two plus the cusco forward carrier bushings :
https://www.ft86club.com/forums/showthread.php?t=117270
86league is offline   Reply With Quote
Old 12-10-2018, 07:49 PM   #3
randomthoughts
Ok thanks. I will definitely consider them as well.
FS; Engine For parts Core Builder+Tranny Harness sokol Engine, Exhaust, Bolt-Ons 1 09-20-2018 05:05 PM
Suspension parts: Whiteline bushings, stock strut parts, Turn in concepts steering FRSPirate Brakes, Suspension, Chassis 6 05-26-2016 03:30 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
POWERFLEX bushings available from Strano Perofrmance Parts Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-18-2012 05:16 PM
pulling e-brake with auto tranny carbonBLUE Engine, Exhaust, Transmission 2 05-16-2012 04:27 PM
