Old 04-06-2017, 12:37 AM   #1
norcalpb
norcalpb's Avatar
DIY - FRONT Shifter Carrier Bushings
I've never seen a DIY for these, but I had similar bushings on my old e36/e46 so so I decided just to buy them and see how to do it.
I bought the Torque Solution bushings seen here:
http://www.ebay.com/p/torque-solutio...d=191170086688
You can also get the Cusco ones here:
http://www.ft86speedfactory.com/cusc...l#.WOXNqYgrLD4
Make sure your transmission is not hot.
1. I only jacked up the front of the car, but for best practice jack up all 4 corners and USE JACK STANDS.
2. Remove the transmission under body panel(not the metal skid plate).
3. Locate the left and right carrier clamps on each side of the transmission. Use a flat head screwdriver to push the tabs towards the rear of the car. Medium amount of pressure is required to do this.
4. Pull the tabs away from the transmission as far as you can. You can also pull them completely out by rotating them and finding a sweet spot where it doesn't hit the transmission tunnel. This is not necessary at all though.
****** I forgot it was helpful to loosen the 2 bolts on the REAR bushing. Loosen them just a little bit, no need to take them all the way out.
Left side:
Right Side
5. Push up on the shifter carrier to free it from it's mounting position. You have a good 4-5" of clearance to work with here which isn't a lot but it's actually VERY EASY compared to the e36/e46 bmws since you can do this with the carrier still in the car.
6. Next you will want to remove the OEM bushings. There are 4 bushings total that support the front of the shifter carrier. Two inner bushings and two outer bushings. The bushings are soft rubber and can very easily be picked and pulled using your hands..
Start with the driver side outer bushing. Use your left hand and dig into the bushing to pull it out.
Passenger side outer is done with your right hand.
Next do the passenger side inner by using your left arm to reach up and over the transmission and use your fingers to pull out the passenger inner bushing. This is why your transmission needs to be cold.
Finally do the driver side inner. This one is tricky because the access point is blocked by the front pipe but I ended up using a 9/64" allen wrench and stuck it through the driver's side bushing hole to stab out the inner bushing just enough so that you can grab it and tear it out of the carrier.
As you can see, the OEM rubber bushings are extremely squishy and will easily tear. The new bushings are much stronger.
2 torn inner bushings
Torque Solution vs OEM
Grease up the new bushings. My Torque Solutions bushings didn't come with grease but I used white lithium grease I had laying around.
With aftermarket, only 2 outer bushings are used, and these slide in very easily. When the bushings are fully pressed into the carrier, pull down on the carrier to lower it back into it's housing. You'll notice there is a little back and forth wiggle room with the carrier, so use that to your advantage when re-installing and re-aligning the carrier tabs/clamps.
Install the transmission cover and you are done!
Impressions:
Overall I can feel a difference with this mod. I currently have the Kartboy short shifter, Kartboy rear shifter bushing, MTEC shifter springs, whiteline transmission insert and Motul fluid.
This dramatically improved how easily the car goes into gear, especially when cornering. It truly feels more like a bolt action rifle whereas before, even with all my shifter mods, it still felt weird putting it into 2nd or even 1st gear at a full stop. This just makes it click in so much easier. I was under the impression that the REAR shifter bushings for our cars would really dial it in, but these front bushings make the package complete.
No extra gear whine from my initial testing.
Old 04-07-2017, 02:19 PM   #2
MJones_RB
MJones_RB's Avatar
Just when you thought you've seen it all... thanks!
MJones_RB is offline   Reply With Quote
Old 05-06-2017, 02:15 AM   #3
Limey
Drives: 2013 FR-S MT Ultramarine
Did mine today and the hint with the Allen key to get the existing inner bushing out helped immensely - much appreciated. I found lining up the carrier to reinsert the bolt to be a bit of a p.i.t.a. In the end I loosened my Perrin rear shifter bushing and it gave enough play to get things lined up.
There's a noticeable improvement, but it didn't remove all of the the play in my shifter like I hoped. Nonetheless I'm happy to have done it. If I were to do it again, I'd do the rear shifter bushing, carrier bushing and trans bushing in one go, just to make life easier.
Limey is offline   Reply With Quote
Old 05-15-2017, 04:28 PM   #4
norcalpb
norcalpb's Avatar
I totally forgot that I had to loosen the rear shifter bushing bolts! I'll update the post with that info.
I agree that there is still play in the shifter even with full aftermarket bushings in the carrier. I think the cause is this tiny black washer not being thick enough.
Rumor has it that getting a thicker metal washer (or possibly even the delrin ones from ace hardware) fixes the shifter rattle.
Old 12-18-2017, 02:36 PM   #5
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Bump. Is it possible to re-install the inner bushings? Perhaps it would get rid of some of the residual play?
ApexEight is offline   Reply With Quote
Old 12-23-2017, 04:29 PM   #6
norcalpb
norcalpb's Avatar
I’m sure you could put the inner bushings back in, but given how soft they are I can’t imagine them doing much. I figure the makers of these bushings feel as if one poly bushing on each side is enough to prevent flex.
The best recommendation I could give would be to get a thicker washer for the bottom of the shifter.
If you want to for sure get rid of the play check out the IRP shifter because it completely eliminates the OEM shifter carrier, and the need for these bushings.
Old 01-20-2018, 10:23 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Update: don't bother taking out the inner bushings. It's not worth the extra time trying to pry them out, and the shifter feels better keeping them in. The Torque Solutions bushings are only designed to replace the outer bushings, not both the outer and inner.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 01-20-2018, 11:10 PM   #8
ApexEight
Still debating on whether or not I want to get these... Seems like major PITA install. I have the Perrin rear shifter bushing and Whiteline transmission mount insert so I'm pretty happy with how it is, though there is still some slop you can feel. I definitely want the MTec springs though.
Old 01-22-2018, 10:06 AM   #9
Bunta93
Drives: '15 CWP Aozora BRZ
Does anyone who has done this mod know if the transmission needs to be removed to install these bushings? On most retailer's websites there seems to be a note saying that the transmission needs to be removed for install.. I was hoping to pick up a set of these and get them installed at a garage when I get my rear shifter bushing and shift springs put in but if the tranny needs to be removed I'll probably hold off
Sent from my BBB100-1 using Tapatalk
Bunta93 is offline   Reply With Quote
Old 01-22-2018, 10:31 AM   #10
amcp1
Drives: frs
You definitely dont need to remove the trans. I've done the front and rear.
amcp1 is offline   Reply With Quote
Old 01-22-2018, 11:05 AM   #11
Bunta93
Awesome, thanks for the input!
Old 01-23-2018, 03:35 PM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
thanks for diy but i dont know if i need this. i feel ok with my mtec shift spring and whiteline transmission insert
Old 02-21-2018, 02:12 PM   #13
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I have the exact same setup, and the inserts made a huge improvement toward positive engagement. Engagement is easier and more direct throughout the shift pattern.
Old 04-25-2021, 11:15 AM   #14
jhoyt
I just did this today on my 2014 BRZ. The advice on loosening the rear bushing helped get the carrier clamp pins back in seconds vs the 10's of minutes I tried before loosening them.
If you're using the CUSCO bushings, you need to remove the inner OEM bushings else the CUSCO outer bushings will not go in all the way. I tried to press them in with several methods but they wouldn't slide all the way in. I removed the inner bushings and they slid all of the way in without much effort.
My method to remove the inner bushings (which was a real pain) was to use a body panel clip pryer (metal not plastic) to both press from outside in to loosen the inner bushing then flip around to the inside and pry them out with the same tool.
jhoyt is offline   Reply With Quote
Cam Carrier Oil Leak (hole in the cam carrier) Subaru86 Issues | Warranty | Recalls / TSB 0 02-22-2017 01:50 PM
TWM Front Carrier Bushing... Ty89m Engine, Exhaust, Transmission 15 10-10-2015 12:09 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-22-2014 11:49 PM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 10:49 AM
*NEW* Scion FR-S Front and Rear Carrier/Stay Bushings | TWM Performance TWMPerformance Transmission and Driveline 0 02-25-2013 05:31 PM
