Old 12-09-2018, 09:42 AM   #1
Icymedlemit
Drives: Sedan
Is it normal for the AC to blow warmer air when under acceleration
I have noticed when I an accelerating that my A/C tends to blow warmer air out while pressing the gas. Is this normal for an 86 is should I get this checked out by the dealership?
Icymedlemit is offline   Reply With Quote
Old 12-09-2018, 10:59 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The AC automatically disengages when accelerating to give you more power for accelerating the car instead of cooling the air. It should reengage automatically when you are no longer accelerating.
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (12-09-2018)
Old 12-09-2018, 01:51 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
The AC automatically disengages when trying to accelerate to give you some power for accelerating the car instead of cooling the air. It should reengage automatically when you are no longer trying to accelerate.
fify
Spuds (12-09-2018)
Old 12-09-2018, 05:26 PM   #4
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I don't find that my AC really disengages when I floor it hard cuz the car is still being bogged down until I turn the AC off.
krayzie is offline   Reply With Quote
Old 12-09-2018, 05:31 PM   #5
Brink
Drives: 2017 BRZ
Do you mean when the A/C is actually running, or when the system is turned off and there's just air flowing through the vents while driving?
Brink is offline   Reply With Quote
Old 12-09-2018, 06:21 PM   #6
jflogerzi
jflogerzi's Avatar
I know this car will blow warm air through the vents during normal driving even if A/C is off. Is this what your describing? If so then yes its normal.
2013 Series 10 FRS #553
Old 12-10-2018, 09:51 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Normal.
Spud nailed it.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-10-2018, 10:35 AM   #8
Originally Posted by 8RZ View Post
Normal.
Spud nailed it.
Yep. Not just normal for this car but for almost every small displacement engine made for the last 20 years. Like so many things it is just more noticeable in these since everything is right there in your face.
humfrz (12-10-2018), Rampage (12-10-2018)
Old 12-10-2018, 11:01 AM   #9
ermax
ermax's Avatar
Every car I've even owned turns off the compressor when accelerating but my FRS seems to be more aggressive with turning it off then any of my others cars. The slightest acceleration will cause it to turn off. I got my car with 80K miles on it and I noticed after accelerating that it didn't seem to cool back off as quickly as I would expect. This got worse with time. It got to where I would be driving along the interstate and it would randomly start heating up for 10 mins at a time before randomly cooling back down. I figured it needed a charge which I did but it have no impact. Turned out the relay was going bad and randomly the compressor would fail to turn back on. I swapped my horn and AC relay and now the compressor cycles consistently and I don't really notice it getting hot when accelerating unless I'm on a back road where I'm not giving it a break. Now I have a horn that randomly doesn't work. One of these days I will get around to replacing it. Hahaha
The Following 2 Users Say Thank You to ermax For This Useful Post:
Tcoat (12-10-2018), Ultramaroon (12-10-2018)
Old 12-10-2018, 11:14 AM   #10
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Huh..never noticed this. I'll have to check it out when I use my A/C again in four or five months. On the flipside, I HAVE noticed that this car takes forever to warm the cockpit, and then only at speed or revving. While idling at a light or tooling around town, I experience temperatures best described as "slightly less chilled."
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 12-10-2018, 11:33 AM   #11
I find that the car is well warmed after about 8 minutes of driving... For my upper body at any rate. I suffered through a broiling head and frozen feet for a couple of months before my grandson figured out what was going on. Next time it is really cold and the heater has started warming your face just reach down the right side of your seat and touch the floor. You will find that even though the cabin is warming there is an artic level cold front coming from under the seat. The temperance variance is so great it is a wonder that thunderstorms don't develop down there. I figure that the cabin layout simply does not let the warm air flow well enough to even out the temperature and the rear stays cold enough to push through to my feet for pretty much my whole 45 minute commute. Now I just shove an old towel under the seat for the winter and my feet are as warm as the rest of me. In fact I now rarely turn the fan above 2 no matter how cold it is outside.
MuseChaser (12-10-2018), spike021 (12-10-2018), Spuds (12-10-2018)
Old 12-10-2018, 12:27 PM   #12
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The AC also takes care of de-humidification.
When you hit defrost, the AC comes on.
Take a minute to knock all the slush off your boots first, and it's not quite as bad.
Old 12-10-2018, 01:26 PM   #13
humfrz
Welcome to the forum and welcome to air conditioned cars -
Yep, like said above, cars with AC have been doing that for years. However, with some cars, back in the day, in the heat of a long road race, on a hot day, we used to manually turn off the AC (less power drain), roll up the windows (for less drag) and turn on the heater (to cool the engine).
humfrz
Old 12-10-2018, 02:12 PM   #14
humfrz
I have had to do that so so many times and not always when racing.
humfrz (12-10-2018), spike021 (12-10-2018)
Coolent temps getting a bit warmer Subz AUSTRALIA 1 04-24-2018 01:58 AM
Is this engine noise normal? (Consensus - normal) StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 31 02-05-2018 04:01 PM
Which oil weight for warmer climates Don Ivey Engine, Exhaust, Transmission 5 03-16-2015 02:12 AM
Warmer switch backs to match DRLs TheBatman Cosmetic Modification (Interior/Exterior/Lighting) 0 07-26-2013 08:58 PM
Winter: Electric car & battery warmer install JSUB BRZ First-Gen (2012+) — General Topics 2 12-26-2012 11:55 AM
