Drives: '13 FR-S
Which oil weight for warmer climates
I'm about to change my oil, and Summer is coming here in NC, so wondered if I should go to something heavier than 0W20. Any comments?
Don Ivey
'13 FR-S (Hot Lava) |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
If you don't track your car with forced induction 0w20 should be fine.
stick to the suggested manufacturer's weight and specs if you haven't significantly modified your vehicle. Ambient temps have little bearing on what goes on inside your engine, where temperatures operate around 190-220F
Check your owners manual
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
driving smoother faster
Drives: Sold
^ That
0/5/10w30 oil will lower your gas mileage a little and it's commonly used for tracked cars (hot weather and high sustained RPMs) |
#6 | |
![]() I thought we gave up that 20w in the winter, 30w in the summer drill, back in the 50s ..... ?? (jest ah messen wich ya ..... serious answers up above) humfrz |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
| What oil are you guys using in hot climates? | No5ki | Southwest | 9 | 06-22-2014 02:40 AM |
| Warmer switch backs to match DRLs | TheBatman | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-26-2013 07:58 PM |
| Center console seat warmer trim, Limited only | BRZPDX | BRZ First-Gen (2012+) — General Topics | 16 | 04-18-2013 02:55 PM |
| Winter: Electric car & battery warmer install | JSUB | BRZ First-Gen (2012+) — General Topics | 2 | 12-26-2012 10:55 AM |
