Old 11-26-2018, 11:40 AM   #1
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
Seibon Carbon Fiber roof turning cloudy after four years, how to fix?
I purchased a Seibon carbon fiber roof overlay for my BRZ four years ago. Earlier this year the carbon fiber has gotten cloudy and it's only getting worse. It's almost like my roof is turning completely white.
Does anyone know how to fix this? I took to a body shop four years ago and they followed the instructions and installed it correctly.
morswestford is offline   Reply With Quote
Old 11-26-2018, 11:49 AM   #2
Gunman
Drives: 2019 Mazda Miata RF
My guess would be any UV blocking in the resin has broken down, or didn't exist.
Gunman is offline   Reply With Quote
Old 11-26-2018, 12:29 PM   #3
morswestford
Is it fixable? How do you fix something that's on the inside resin?
Are my only options
1) remove entirely, go back to oem roof
2) remove and replace with new carbon fiber roof layer? (why would i do that again if this is what happens?)
Old 11-26-2018, 12:49 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is common for carbon fiber components, you can find a lot of information in a myriad of placed. Generally wet sanding and re-applying clear is probably your only bet to save it.
DarkPira7e is online now   Reply With Quote
Old 11-26-2018, 03:38 PM   #5
kch
Senior Misanthrope
kch's Avatar
Agreed with above. Most CF trim pieces are only gel coated and lack any UV protection. Solution now is to wet sand and clear coat. Solution in the future is to take new pieces to get a clear coat before installing.
Old 11-26-2018, 04:15 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Easy fix, sand and re-clear.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-27-2018, 06:52 AM   #7
morswestford
thanks everyone for the advice.
does anyone know how much is a good price to pay for a body shop to sand it down and add a clear coat on it? most body shops i know of don't really specialize in carbon fiber. do you think most shops would be able to handle that?
and it's probably cheaper to go the wet sand and clear coating route than removing the carbon fiber and going back to OEM roof because then i would have to get the roof re-painted because of all the glue and whatever is stuck between the roof and carbon fiber layer.
Old 11-27-2018, 09:53 AM   #8
toast
Drives: 14 BSP Edelbrock BRZ
It is trivial to do this yourself if you have a workspace. Go to your favorite AutoZone-type place, grab a pack of 800 grit sandpaper. Apply tape to any neighboring part edges and wetsand with a spray bottle. Order a can of SprayMax 2k high gloss clear. Mask off everything close and drape the rest of the car with a drop cloth of some sort. Spray 2 light coats and 1 final medium coat of the clear with 10 minutes of flash time in between coats. Most people will be done at this point. If you want to make it like glass wait at least 24 hours and wetsand with 2000 grit sandpaper and follow with polish.
toast is offline   Reply With Quote
Old 11-27-2018, 12:09 PM   #9
morswestford
wow easier said than done, haha. i think i will just go to a body shop.
Old 11-27-2018, 01:51 PM   #10
kch
Senior Misanthrope
kch's Avatar
Like $250? Maybe less if you do some prep work yourself.
They don't need to specialize in CF, as they won't get all the way through the gel coat. They just need to get rid of the oxidation. It'll be just like any other job for them.
Old 11-27-2018, 03:15 PM   #11
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
we would charge around $300 to re-clear. I have had some carbon that has had gel coat failure all the way down to the weave. no way to tell until you start sanding it down
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 12-02-2018, 12:33 PM   #12
morswestford
awesome thanks for the advice.
S-craft Carbon Fiber Nose Cover Becomes Cloudy morswestford Cosmetic Modification (Interior/Exterior/Lighting) 4 10-10-2016 12:48 PM
FS: Seibon CSL-Style Carbon Fiber Trunk Lid / Seibon VS Style Carbon Fiber Hood FRSPhil Exterior Parts (Aero, Lighting, Etc.) 24 07-29-2015 12:31 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 10:51 AM
Seibon CF (Carbon Fiber) Hood, Roof, & Trunk - $2100 - Nor Cal / Nor Nev Snozzberries Exterior Parts (Aero, Lighting, Etc.) 18 07-31-2014 01:18 AM
Seibon Carbon Fiber Roof Fin Spoiler kombatlion Cosmetic Modification (Interior/Exterior/Lighting) 0 04-04-2013 11:12 AM
