Old 11-25-2018, 02:33 PM   #1
DillonJay
Drives: 2014 BRZ Turbo
Is my motor built?
I just bought a turbo BRZ. No papers but the price was too good to pass up. It has the SBD 500x kit and the install is super clean. I looked over every inch of this car and all the work (suspension, gauges, exhaust. etc.) is all done really well with nice brand name parts.
For my question....it has an ethanol gauge which leads me to believe it has an 85 tune (has an OFT) and it’s running about 12psi. I am pretty sure it’s been ran this way for the last 10k miles. (Car has 19k). It all seems unsafe for the stock motor but the car runs great and it’s FAST. I’m not too familiar with the FA20. Are there any key things to look for to figure if the motor has aftermarket internals? Will I see anything if I pop the valve covers?
Edit: It’s not running the 85 tune now but it is an option just to be more clear.
Any help is appreciated.
DillonJay is offline   Reply With Quote
Old 11-25-2018, 02:56 PM   #2
humfrz
Hello DillonJay and welcome to our happy group -
Have you tried to contact the former owner for the answer to your question?
As far as I know, the only way you could tell whether or not the engine had been "built" would be to disassemble the engine.
If you got a really great deal on the car, I doubt it has a built engine.
humfrz
DarkPira7e (11-25-2018)
Old 11-25-2018, 03:13 PM   #3
DillonJay
humfrz
I bought the car from the second owner and he bought it this way. He didn’t know anything about it or much about cars in general. He said he didn’t change a thing on it since he bought it. I don’t think he really understood the money that someone put in the car so he had it priced low and he wanted it to go fast with winter around the corner. I asked about a previous owner but he didn’t know. He tossed all of the paperwork out that came with the car and couldn’t tell me much at all. He had papers for regular easy maintenance which helped me trust everything he said. Even paid a shop to change the battery...
But I guess the safest thing I can do is turn the boost down and treat it as if it is a stock motor. Perhaps try to continue to track down the first owner.
The Following User Says Thank You to DillonJay For This Useful Post:
humfrz (11-25-2018)
Old 11-25-2018, 03:16 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Not really a complete give-away, but see if the rear cam seal was replaced; it's a cheap to-do mod that most people won't pass up when they have the engine out. See if there's any ultra fresh looking RTV anywhere someone may have used.
DarkPira7e is online now   Reply With Quote
Old 11-25-2018, 03:30 PM   #5
DillonJay
I’ll check it out. Whoever did the work knew what they were doing so I have a hard time believing they’d run stupid boost on 85 and risk blowing it up. I mean the gauges are way better than they need to be. The coilovers aren’t a cheap setup and they are all in sleeves. Everywhere I look the more impressed I am with it.
Thanks for the help.
Old 11-25-2018, 03:38 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I highly doubt it will be a built motor. A lot of people slap turbos and superchargers on and hope nothing goes pop. I also wouldn't base gauges on whether the engine was built.
MS, CSCS, TSAC-F, CPT
The Following 5 Users Say Thank You to weederr33 For This Useful Post:
aimforapex (12-06-2018), ajcarson11 (11-26-2018), humfrz (11-25-2018), kch (11-26-2018), Sportsguy83 (11-27-2018)
Old 11-25-2018, 03:41 PM   #7
DarkPira7e
DarkPira7e's Avatar
Certainly seems like they did some tasteful mods, but never ever assume they did the modifications with the interest of engine longevity in mind - It'd be far better to err on the side of caution and get it checked out. I'd have someone dissemble part of the engine and check the internals as has been suggested. Knowledge is power! Better to know what has/hasn't been done than to wonder. Definitely do not trust them to have done the build right though
Old 11-25-2018, 03:44 PM   #8
humfrz
Good plan!
humfrz
Old 11-25-2018, 06:08 PM   #9
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Pull fuel rail cover and check fuel injectors. If they have swapped those out, then it's more likely that you keep looking into the motor itself. If they have not been, then you most likely have a stock motor with a bolt on turbo kit.
Also, most built motors will be tuned via EcuTek.
I see you are in WI..... Whereabouts?
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 11-25-2018, 10:02 PM   #10
Norotor
Drives: '13 FRS, '18 WRX, '21 M3
Do you hear piston slap during cold starts?
Norotor is offline   Reply With Quote
The Following User Says Thank You to Norotor For This Useful Post:
DarkPira7e (11-26-2018)
Old 11-25-2018, 10:12 PM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
SBD? OFT? And you wonder if the motor is built?
Cheap is as cheap does. It's not built. And it probably wasn't the deal you imagine it to be...
The Following 5 Users Say Thank You to cjd For This Useful Post:
ajcarson11 (11-26-2018), arkanist (11-26-2018), EAGLE5 (11-25-2018), kch (11-26-2018), Kiske (11-26-2018)
Old 11-25-2018, 10:40 PM   #12
86MLR
86MLR's Avatar
Who knows, throw up some pics on here, someone might know the car and Google search the plates
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 11-25-2018, 11:03 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What suspension does it have? Odds of your motor being built are 99:1.
Old 11-25-2018, 11:42 PM   #14
highway7
Drives: FRS 2013
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
weederr33 (11-27-2018)
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
Anyone with a built motor using a GTX3071R? Darryljr11 Forced Induction 5 11-12-2015 10:03 AM
10.5:1 Built Motor. alexisfire02 Engine, Exhaust, Bolt-Ons 16 03-24-2015 10:06 AM
which built motor? Fabron757 Forced Induction 82 11-26-2013 10:08 AM
