Old 11-18-2018, 12:10 PM   #1
Blackedout86
Drives: 2012 Toyota FT-86
local custom made headers ? how good or bad is it ?
hello, can anyone please enlighten me about custom made headers, i cant get any aftermarket headers. Would it be better to ask local shop to replicate catless stock header but slightly increase its size, or just remove the cat on the stock header ?
i have no clue about air flow on the header, but i can see that my local shops can't do Mandrel Bend which means they just cut small pieces of pipe and weld it to replicate the stock header's curves, does it really affect the power ?
Thanks before
Blackedout86 is offline   Reply With Quote
Old 11-18-2018, 03:24 PM   #2
humfrz
Thanks before
Question: Why can't you get an aftermarket header?
If you can't get an aftermarket header and your local shop has limited fabrication capabilities, I would suggest you just leave it alone.
humfrz
Old 11-18-2018, 04:46 PM   #3
86MLR
86MLR's Avatar
Find a 17+ header and either just knock out the cat (what I did) or cut the cat section out and replace with a pipe section.
Easy and cheap, and typical gains to alot of aftermarket headers.
Plus you can keep the OEM heat sheilds.
Simples
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 11-18-2018, 09:24 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It all depends how the bends are made.
If it's just a cheap old pipe bender then the flow won't be as good.
If they have a good mandrel bender then it's pretty much what every aftermarket header uses.
Not sure how good local shops are but, if he's into Motorsports and has a good rep for making dyno proven results then why not?
If it's just some hole in the wall muffler shop, eh, it's your call. Who knows.
Old 11-18-2018, 09:29 PM   #5
Brink
Drives: 2017 BRZ
They wouldn't be making bends.
Brink is offline   Reply With Quote
Old 11-18-2018, 09:55 PM   #6
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
the cat is the restriction on the stock headers. I wouldn't just gut the cat though. A gutted cat has a lot of turbulence. I would just have him weld in a straight pipe in place of the cat
SuperTom is offline   Reply With Quote
Old 11-19-2018, 12:28 AM   #7
Blackedout86
humfrz
The car is quite rare in my country, so its aftermarket products are very limited, and shipping them from outside the country is just too complicated and expensive, im just looking for a simple and cheap alternative
The Following User Says Thank You to Blackedout86 For This Useful Post:
humfrz (11-19-2018)
Old 11-19-2018, 12:34 AM   #8
Blackedout86
Simples
Can you give an comparison example of the catless stock header with aftermarket ones ? Is it as good as Borla uel, for example.
Or even better, is there a dyno numbers on this mod alone ?
Old 11-19-2018, 01:54 AM   #9
86MLR
86MLR's Avatar
http://www.ft86club.com/forums/showt...76#post2420676
You will need a mini cat until you get a tune so you don't throw a code.
I got one of these >
Lots of km, both hwy and general trashing around, no codes.
I really need to get a tune though, and a pipe welded on.
My mate replaced his catless OEM header (with a pipe welded in) on his 2015 with a SME header, cost him about $1000, after tuning there was a few extra hp up top, but he believed the money wasn't worth the few extra hp.
He reckons he feels no noticable difference anywhere in the rev range.
And yes it was tuned.
I was looking at headers before I talked to him, now, I'm just gutted.
But, this is only one example.
Old 11-20-2018, 04:03 PM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I could have sworn someone made nearly this exact thread a few months back.....
Old 11-20-2018, 10:28 PM   #11
Lantanafrs2
Drives: 2013 frs red
[QUOTE=Blackedout86;3156382]Can you give an comparison example of the catless stock header with aftermarket ones ? Is it as good as Borla uel, for example.
No, it isnt
Old 11-21-2018, 12:59 AM   #12
Blackedout86
i think i've seen the other thread, but the tested car is supercharged and has many other mods, i just want to know the numbers on removing the cat alone, on stock car.
edit : one more thread with similar topic has the tested car modded with e85 fuel
Old 11-21-2018, 01:42 AM   #13
86MLR
86MLR's Avatar
LOL
Anyways, IRT modified OEM header, if your happy spending over 1k$ there are better options.
If you are at the pointy end of the field, there are better options.
If you want a performance mod for minimal cost and "most" of the gains, you cannot go wrong with a modified OEM header.
If by chance you want that extra couple of hp up higher in the rev range, or more torque in the mid range, buy a EL, UEL, long runner, short runner, small pipe, big pipe, 4:1, 4:2:1.
There are enough headers out there to pick where you want what IRT the hp/torque a header will give a NA FA20.
Me, I looked at my 17 OEM runner and secondary sizes and lengths, I asked around at the track and did alot of googling, luckily for me I had a mate who did the hard work and the cash outlay on this, from all of this I came up with my decision of what would give me best bang for my buck, $150 for the modified OEM pipe, or over 1k$ for a couple more hp up top, I chose the $150 option.
In the end do whatever the hell you want, as long as your choice is based on sound engineering and not just what people post on the interwebs.
Edit: plus money saved will go on dyno time for ECUTEK (when I pull my finger out of my arse and get it tuned, + rev match, I'm rubbish at heal/toe)
But don't listen to me, I'm just a crazy old hoon posting on the interwebs ��
Berk Dual Muffler Delete vs Local shop made? FSpeed Scion FR-S / Toyota 86 GT86 General Forum 9 10-28-2014 11:06 AM
Found a good place with good price for ceramic coating for headers CamryDS Northern California 0 03-28-2014 05:03 PM
Local made muffler delete supramkivtt2jz Engine, Exhaust, Bolt-Ons 7 11-03-2013 12:51 AM
My FR-S made the Compilation vid of last local open drift :) MarkRacerX FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 31 09-19-2012 10:37 PM
