Old 10-27-2014, 01:41 PM   #1
FSpeed
FSpeed's Avatar
Drives: 14' WhiteOut FR-S
Berk Dual Muffler Delete vs Local shop made?
Just a quick question for the more experienced members on the forum.
If I had a local shop make me a "Berk dual muffler delete replica" (save a little money), how would that be different from the original? Is the sound different or anything else, I mean I don't know all the technical details when it comes to this. It seems simple enough for someone to weld some pipes and tips together that mimics the one made by Berk.
I would really appreciate an answer. Thanks in advance.
2014 Whiteout FR-S
2008 Lexus IS-F
1997 Toyota Corolla
FSpeed is offline   Reply With Quote
Old 10-27-2014, 01:52 PM   #2
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
Stainless vs aluminized steel is probably the biggest difference. Not many local exhaust shops use stainless. I'm sure you might be able to hunt down a shop that uses stainless but theyre hard to come by in my experience.
VacantSky is offline   Reply With Quote
Old 10-27-2014, 01:53 PM   #3
Kaotic Lazagna
Drives: GR Corolla
Will more likely sound the same. However, quality may differ (i.e. quality of welds, tips, etc). Also, fitment could become an issue. You won't want a lopsided exhaust. I've always had an exhaust made, but those cars always had the exhaust tips on one side. Didn't want to take a chance with the FR-S.
Old 10-27-2014, 02:04 PM   #4
FSpeed
FSpeed's Avatar
Thanks for the feedback guys, much appreciated.
2014 Whiteout FR-S
2008 Lexus IS-F
1997 Toyota Corolla
Old 10-27-2014, 02:17 PM   #5
VacantSky
The Angry Brit
VacantSky's Avatar
Just to piggy back on what lazagna said, I had a muffler delete made for a previous car. It was only single tip BUT the shop that did it took the tip and put it up on a tall jack (like one to jack an engine up a little if your under the car) and centered it in the tail pipe opening then tack welded the delete together. I'm sure they could get both tips even using this same method.
Old 10-27-2014, 08:28 PM   #6
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
I have a local shop muffler dual tip and it sounds great. I put a resonator to cut down the drone. But still sounds great still
KungFuWaffle is offline   Reply With Quote
Old 10-27-2014, 10:45 PM   #7
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I have local made muffler delete and its great save about $200 getting it from a local shop who had never done a twin. Love it to death!!
Old 10-27-2014, 11:34 PM   #8
afoust50
afoust50's Avatar
Drives: 2014 Scion FR-S
Bought my Berk dual exit delete here
http://www.ft86club.com/forums/showthread.php?t=53447
Quality is top notch. Fitment is perfect. I thought about having a local shop make me one but eventually decided to spentdthe extra $70 to know exactly what I was getting.
afoust50 is offline   Reply With Quote
Old 10-28-2014, 09:07 AM   #9
extrashaky
Drives: 2014 BRZ Limited
If you have a local muffler shop try to make a direct copy of the Berk, they'll most likely use straight pipe in a crush bender rather than welding together mandrel-bent pieces. Most muffler shops do not have mandrel benders to do it right. The airflow disruption from the creases in the bends probably wouldn't make that much of a difference, but they might bug you if you knew they were there.
Old 10-28-2014, 11:06 AM   #10
FSpeed
FSpeed's Avatar
Thanks everyone! Im hoping i can hunt a berk one down since they were having trouble with shipment a few weeks ago. If not I may be forced to go back to my local shop.
2014 Whiteout FR-S
2008 Lexus IS-F
1997 Toyota Corolla
Berk dual muffler delete Cu0ngsayz Want-To-Buy Requests 0 04-20-2014 08:02 PM
FS: Berk dual muffler delete xia Engine, Exhaust, Bolt-Ons 4 03-11-2014 06:16 PM
Local made muffler delete supramkivtt2jz Engine, Exhaust, Bolt-Ons 7 11-03-2013 12:51 AM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 04:20 PM
FS: BERK Muffler Delete Dual Tip stanm Engine, Exhaust, Bolt-Ons 17 12-03-2012 10:13 PM
