Old 11-17-2018, 06:09 PM   #1
Mr_Eyo
Drives: 2017 Toyota 86
Installing Fumoto oil drain valve, question on gasket and crush washer
I'm about to install the drain valve and it comes with a rubber gasket. I got a new crush washer in anticipation for this install, but I am now questioning the order these 2 would be installed. Is it even advisable to use both,. If so, what is the install order (pan>crush washer>rubber gasket>drain valve)?
Thanks.
Mr_Eyo is offline   Reply With Quote
Old 11-17-2018, 06:44 PM   #2
86MLR
86MLR's Avatar
IIRC, I just used the OEM crush washer.
I'm no expert but using 2 washers doesn't seem like a good idea engineering wise.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
gravitylover (11-17-2018)
Old 11-18-2018, 12:11 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
A "crush washer" does just that.
It would "crush" a secondary rubber washer to useless bits before it did it's primary job.
My FuMoto came with a fiber washer a few years ago.
I used that along with clean surfaces and a slight film of RTV sealant.
I don't anticipate needing to remove it again for the life of the oil pan.
I don't recall exactly how wide the sealing surface is on the valve itself,
but I don't think that it is wide as the original pan bolt.
If the valve was supplied with a washer, use that instead.
Don't torque it to metal bolt / metal washer specs. That would split the rubber.
Old 11-23-2018, 01:16 PM   #4
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I used the included rubber washer.
Do not install both. Crush washer will not "crush" properly with a rubber washer next to it.
When you tighten down the valve, make sure you tighten it with a crescent wrench on the body of the valve and not a socket on the hex end of the valve or you will damage it:http://www.fumotousa.com/installation.php
Enjoy your easy oil changes!
wolffbite is offline   Reply With Quote
Old 12-04-2018, 08:42 AM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I just used the fiber washer that came with it, going on 3 years soon with no leaks.
Trueweltall is offline   Reply With Quote
Old 12-04-2018, 11:15 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
This.
Current DD: M235i
8RZ is offline   Reply With Quote
First Oil Change, Fumoto Oil Drain Valve oldnotdead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 07-23-2021 12:39 PM
FS: Fumoto Drain Valve turbos86 Engine, Exhaust, Bolt-Ons 2 03-15-2017 06:41 PM
OEM Oil Drain Crush Washer Buying Tip radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-20-2016 09:42 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 06:27 PM
