Old 11-16-2018, 04:19 AM   #1
eTiLiKo
Drives: black widow
Trying reading an EDM MT 2018 GT86
Hi guys, as per the title I'm trying reading a 6MT Toyota GT86, same as BRZ. It is a May 2018 car, ID K00G.
I use subaruBRZ SH72531 in ecuflash 1.44.4799
But the file I obtain is a 1248Kb file instead of a 1280Kb file. I have tried two times with the same result. File attached
Any idea of what's going wrong?
eTiLiKo is offline   Reply With Quote
Old 11-16-2018, 05:14 AM   #2
eTiLiKo
Drives: black widow
Tried with another device (Alientech kess) and I finally have a 1280Kb file. It seems that ecuflash doesn't fill the initial and final part of the file with 00 (or FF) to obtain the 1280Kb file.
Old 11-16-2018, 05:18 AM   #3
JIM THEO
Drives: BRZ 2018
Seems weird, I read my MY18 - same call ID K00G - easily with Tactrix and standard Subaru BRZ mode!
JIM THEO is offline   Reply With Quote
Old 11-16-2018, 05:49 PM   #4
steve99
if you save file in ecuflash as SRF format file will be larger as it contains extra info for tactrix guys use as well as rom/tune data.
Just save the read file as BIN format and you will be fine
It will pop up an error about some data lost but that ok it will save the 8000-13FFF section ok.
you will then end up with same file as you read/saved with Kess V2
WORKS Motorsports 2018 FRS / BRZ / GT86 Products & Prices WORKS Announcements, Contests, Giveaways 0 01-27-2018 07:51 PM
2018 calendar pics - ONLY BRZ/FRS/GT86 aleccentric FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-23-2017 09:48 AM
BRZ / FR-S / GT86 only 2018 calendar (Only 40 copies left!) aleccentric Announcements, Contests, Giveaways 0 12-18-2017 08:34 PM
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 06:44 PM
