Old 11-15-2018, 02:01 AM   #1
danielmailrs
Asphalt grinder
Drives: brz
gearbox and diff oils
hi
so after looking around the forum ive seen that many of you guys like the motul 300 oil.
i decided to go with that one too-the thing is ive found 300LS and 300 .
should ill put the LS in the gb and diff together or 300 in gb and 300LS in the diff?
regular :https://www.motul.com/us/en-US/products/gear-300-75w90
LS :https://www.motul.com/us/en-US/produ...r-300-ls-75w90
thanks
danielmailrs is offline   Reply With Quote
Old 11-15-2018, 02:15 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by danielmailrs View Post
Hi.
So after looking around the forum I've seen that many of you guys like the Motul 300 oil.
I decided to go with that one too. The thing is I've found 300LS and 300.
Should I put the LS in the gb and diff or 300 in gb and 300LS in the diff?
Regular: https://www.motul.com/us/en-US/products/gear-300-75w90
LS: https://www.motul.com/us/en-US/produ...r-300-ls-75w90
Thanks.
Ftfy.
Ultramaroon (11-21-2018)
Old 11-15-2018, 02:51 AM   #3
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
curious to know this also!
jbsali is offline   Reply With Quote
Old 11-15-2018, 04:58 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Transmission - Motul 300
Diff - 300 LS, People have run 300 without problems.
I'd suggest Redline 75W-85 for diff - https://www.redlineoil.com/75w85-gl-5-gear-oil
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
CSG Mike (11-21-2018), danielmailrs (11-15-2018)
Old 11-15-2018, 05:37 AM   #5
danielmailrs
Asphalt grinder
Drives: brz
After talking with fellas that own brz too they said our diff is torsen lsd that doesnt require an ls oil. So the normal 300 is more recommended(some of them even said that ls oil can be even worse to our diffs)
Sent from my SM-G960F using Tapatalk
Old 11-15-2018, 06:10 AM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
It kind of depends on who you ask as to which is more recommended.
I have never heard that the 300 LS can be worse.
Yes, we have a torsen not clutch LSD. So technically no friction modifiers are necessary.
Motul company themselves still suggests 300 LS over 300. Ultimately the friction modifiers won't do any extra harm to our LSD. I believe some people have noted they preferred how the 300 LS locked up the LSD over the 300. I think it was CSG Mike?
300 LS - All hypoïd differentials with limited slip system, gearbox with integrated limited slip differential, mechanical transmission, synchronised or non synchronised gearbox, transfer gearbox operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speed
300 - All mechanical transmission, synchronized or not synchronized gearboxes, gearbox/differential, transfer gearboxes and hypoid differentials without limited slip system operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speed.
Feel free to put in what you want.
The Following User Says Thank You to Bonburner For This Useful Post:
danielmailrs (11-16-2018)
Old 11-16-2018, 05:35 AM   #7
danielmailrs
Asphalt grinder
Drives: brz
yeah
looks like its open for personal choosing
cuz either way youll go you wont be wrong
Old 11-21-2018, 01:27 AM   #8
Legend@wheels
nenber
whats LX stands for ?is it like LS?
Legend@wheels is offline   Reply With Quote
Old 11-21-2018, 06:55 AM   #9
Legend@wheels
nenber
i have just changed my gb oil and the diff oil with motul300 75 90 .(no ls)
and tbh?i cant see whats all the fuss is about -it feels almost the same as the previous oil and the gears changing are still shitty (especially 2nd to 3rd so notchy like in other gearboxes i would say its fault gb that require rebuild)
Old 11-21-2018, 08:50 PM   #10
Gear 300 will work in a Torsen, but not with any aftermarket LSD.
Also, while rated the same, Gear 300LS is actually more viscous than Gear 300.
Oils aint oils Sol ZAZ AUSTRALIA 8 02-14-2020 07:02 PM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 07:01 PM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 01:07 AM
Was doing the transmission and diff oils today, when... what is this thing? Entroper Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 03-12-2013 12:40 AM
Clutch / Diff / Gearbox issue? doggy Issues | Warranty | Recalls / TSB 5 10-03-2012 11:47 AM
